Power Wire through Firewall, where?
Old Aug 18, 2006 | 10:54 PM
9GMC9's Avatar
Originally Posted by laynlow77
ghetto ^^^^ run it through the spot for the clutch pedal that you probably dont have used. under the driver side dash. easy to find
****, it works perfectly fine, and no ****** drilling or forcing **** throught nothing. Done and working like a champ.
Old Aug 18, 2006 | 11:05 PM
laynlow77's Avatar
im not saying it doesnt work...hell you could run it outside the truck and it would still work. im just saying that it doesnt look the best, and there are easier ways to do it.
Old Aug 18, 2006 | 11:53 PM
9GMC9's Avatar
Look the best? You want it to look the best or to power your amp?!
Old Aug 19, 2006 | 12:04 AM
laynlow77's Avatar
ok read my post above again, maybe you missed something.....
Old Aug 19, 2006 | 12:43 AM
9GMC9's Avatar
Dont mind me bro, kinda buzzin, do what u wanna do, or whatever.
Old Aug 19, 2006 | 12:50 AM
Coban's Avatar
I ran mine through the grommet with the main harness. No extra holes.
Old Aug 19, 2006 | 11:02 AM
Taylorkdt's Avatar
I used the stock gromet, and I have also drilled a hole where the clutch mounts up. The foam on the inside of the fire wallis cut out and their is a circle indented in the firewall, I drill it from the inside.
Old Aug 24, 2006 | 05:27 AM
Thanks guys!
Old Aug 28, 2006 | 11:57 PM
blue 01's Avatar
I wouldn't run it through the main harness boot unless you are using a big barrel fuse or circuit breaker. I heard of some that have used a plastic maxi fuse holder and if it ever grounds out the connectors can melt together. Then the power wire starts to melt your factory harness. Not good, or cheep to fix.
I ran my through the fender and door like the 9GMC9. Barrel fuse before it goes in the fender and a large maxi distribution block before the amps.
Old Aug 31, 2006 | 01:07 AM
desTRUCKtive's Avatar
ok this guy has a point.... but I ran mine through the factory harness without at slit. if you guys pull that grommet out towards the engine bay it will pop off. then slide the wire go inside the cab and pull that grommet toward the rear of the truck and it will snap right on again . looks good
ARC
57
Feb 21, 2022 10:54 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MWRitter
Jul 27, 2015 09:41 AM
