New alpine type r?
Old Apr 1, 2013 | 10:56 AM
Jblake's Avatar
Default New alpine type r?
Anyone tried out the new type r subs yet? More specifically in a 10? My amp will push 1000 watts at 2 ohms which is what the sub calls for at rms. wondering how they hit with that or close to it
Old Apr 1, 2013 | 12:58 PM
WICK3DxGATA's Avatar
you need to make sure you have enough air apace and decide weather it will be a sealed or ported enclosure. your amp should be fine.
Old Apr 1, 2013 | 01:37 PM
Jblake's Avatar
The box is .8 cubic feet. It's the same one bassworx makes for under the seat in an ext. cab truck. But I made it on my own and extended it a bit to make a little more space than the bassworx box. The sub calls for 1 cubic foot. So I'm just shy of it.
Old Apr 1, 2013 | 02:26 PM
Jblake's Avatar
Never mind the sub calls for .55cft. With a sealed box
Old Apr 1, 2013 | 03:09 PM
jbancs's Avatar
This new year all the subs have pretty much moved up a class. The new type S is equivalent to the last year type R. The new Type R is equivalent to the old Type X. They sound absolutely amazing in a proper enclosure. Doesn't matter what Alpine says, I'd never run a type R sealed, and definitely not in an enclosure that small sealed. Type S would probably be more up your alley, and if you're responsible with the listening, running it off 1000 watts wouldn't be instant death for it either. Just my $.02
Old Apr 1, 2013 | 03:53 PM
i also agree with ^^^ i would not run it sealed but if its all you got then i guess it would be fine.
Old Apr 1, 2013 | 05:05 PM
Jblake's Avatar
So if I put a port In my box i would be better off?
Old Apr 16, 2013 | 09:16 PM
jbancs's Avatar
you shouldn't just put a port in the box. Subs require different specs for ported enclosures vs sealed. Not the least of which is ported enclosures need to be larger, and you have to factor in port displacement.
Old May 6, 2014 | 07:35 PM
99silvy's Avatar
they are one of the best!
simman22
Jan 21, 2017 10:27 PM
Angry Silverado
Oct 21, 2015 07:07 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
97_ek
Sep 23, 2015 09:16 PM
screaminian47
Sep 7, 2015 08:20 PM
