nasty case of alternator whine through speakers, help
Old Aug 28, 2013 | 12:16 PM
  #21
full foot notch's Avatar
Make sure your grounds are to a good point and not just against painted metal. Needs to be bare metal. And I usually try to ground within 18" of amp. As mentioned before making sure the signal and power wires are separate by I would say 12 inches
Are they shielded RCAs ? But 95% of the time I've found it's not a proper ground. And if not that then a faulty signal or bad equipment internally
Old May 6, 2014 | 07:34 PM
  #22
99silvy's Avatar
that can happen if your rca cable runs next to your rpm gauge wire. they sell a filter for it that plugs into you stereo and its like 30 bucks i believe. my brother had it happen in his tahoe
Old Sep 25, 2022 | 04:17 PM
  #23
wardlws's Avatar
'12 AWD Platinum Escalade
I'd like to thank everyone who mentioned "bad ground wire". That was my issue, and here is why... I used a factory body bolt and nut to attach my amp's ground wire. I hit them with a scotch pad / steel wool pad, but they are both painted with thick primer. Scuffing them up allowed them to pass enough current to get the amp to work, but not enough to avoid alternator whine.
I bought a set of these to go on the end of my drill:
It still took a few minutes to reach shiny metal, but once all of the contact area on the body, bolt, and nut where down to bare metal... no more alternator whine!
So... thanks!!!
Striped02WS6
Jan 7, 2010 12:09 AM
zittman
Nov 16, 2009 01:35 PM
2k4tahoe
Oct 11, 2007 11:06 AM
LesPaul
May 15, 2007 09:57 PM
04chevy5.3
Dec 7, 2006 11:06 AM
