engine noise
Old Oct 30, 2009 | 02:27 PM
zittman's Avatar
Default engine noise
How do you get rid of engine noise through my stereo system? It drives me nuts!!!! If I put the power wire from the amps say on a top post battery and run the power to the alt. starter, etc to the side post will that make a difference? I was also told to use a larger ground on the battery to the engine. I have the noise reducers already on the rca jacks before the amps and that did not change anything. Any help would be great.
Old Oct 30, 2009 | 02:55 PM
skeet's Avatar
the ground from the amps or amp needs to be really short, short as you can get them, yes the ground wires need to be bigger than the power cable.
Old Nov 2, 2009 | 06:22 PM
f4tal's Avatar
Ya ^^^ what he said, and the ground really needs to be no more than 12 in. at most, the shorter the better and nothing smaller than 4gauge for the ground wire
engine noise most times has to do with grounds or the RCA cables being run along the power wire also can cause interference
Old Nov 2, 2009 | 06:26 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Also, stay away from cheap low-dollar amps.
Old Nov 2, 2009 | 07:22 PM
04BlackSilverado's Avatar
Aftermarket Spark Plug wires will cause interference as well
Old Nov 3, 2009 | 12:13 AM
zittman's Avatar
Well the ground wire for the amps are short as I can have them and they are larger than the power cable. I also ran the power wire on the driver's side and ran the RCA cables on the passenger side. Anything with the actual power wire for the truck itself? I guess I will have to get a bigger ground for the amps and the truck also. Thanks
Old Nov 3, 2009 | 12:15 AM
zittman's Avatar
It was a $900 amp. It is a professional series amp. 380rms X4. The sub amp is a MTX.
Old Nov 4, 2009 | 08:54 PM
53bowtie's Avatar
Your grounds on your amps should be fine as long as you cleaned the spot they are attached to on the body of the truck. The size and length of the ground wires dont have as much to do with anything as long as they are at least the same size as the poer wire. If your rca's arent near any wires running from the engine bay I would look next at grounding the engine to the frame with some 1/0 ga. wire or something that size.
Old Nov 4, 2009 | 09:24 PM
sappy's Avatar
Registered User
you kids now a days with ur freaking amps make me crazy.. no im not gonna take my pills for the next 3 days and most likely beat my step kids because of this thread.. good job...
Old Nov 16, 2009 | 01:35 PM
f4tal's Avatar
Originally Posted by sappy
you kids now a days with ur freaking amps make me crazy.. No im not gonna take my pills for the next 3 days and most likely beat my step kids because of this thread.. Good job...
wtf??!
black03rcsb
Sep 1, 2015 10:17 AM
superchomper2003
Aug 26, 2015 09:39 AM
V-seriesTech
Jul 28, 2015 12:31 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
