large draw on radio circut(70ma)
Old Oct 26, 2008 | 04:55 PM
Default large draw on radio circut(70ma)
I finally (i think, i hope) found my dying battery problem. I hooked up a multimeter between the negative terminal wire on the battery and started pullin fuses. I got to the radio fuse and all went down to 07 ma. What all is on that circut, I want everything. I know that the guage cluster is on there as I pulled the fuse for safe keepin and lost my guages. I have an aftermarket stereo and deck. Which have been in there for years so I don't think its that. And its a big project to go through that so I figured that i'd start small. Any suggestions.
Old Oct 27, 2008 | 10:46 PM
WhiteRhino's Avatar
A short somewhere in the system. A blown speaker can cause it as well.
Old Oct 30, 2008 | 01:59 PM
bump..
Old Nov 1, 2008 | 10:27 PM
damn it, well it was going good for a week then I parked the truck one morning after grayvies and didn't touch it again intill two days later and ....click...click...click. And the fuse was pulled like always as I haven't chased it yet. So I guess i'll go and check for a draw again but like I said it was only .07mv after i pulled the problem fuse so that don't make sense. Also the battery was tested and good as that was the first thing I checked.
Old Nov 7, 2008 | 05:18 PM
006rcsb's Avatar
dammer, keep us posted on this one!
Old Nov 17, 2008 | 10:32 PM
Well so far I have traced it back to the guage cluster. I spoke to the dealer and they said that they have had problems with the cluster pack shorting out and causing a substantial draw. The solution is to replace the cluster.....which is quite expensive.
Old Nov 18, 2008 | 10:20 PM
ahhh... mabey not I musta missed the fuse for the bcm and its loses voltage when disconnected. I did a voltage check again as the battery was dead again with the guage cluster disconnected this mornin. This time there was about .05 voltage draw then all of a sudden it went up to .70 so I started pullin fuses again and when I pulled the bcm the voltage went down to .05 just the same as the radio fuse except the bcm takes about 5-10 secs to go down in voltage. The thing wit hteh cluster is it gets some info from the bcm so thats the link there. Gonna dig further into it tomorrow.
Old Nov 22, 2008 | 07:39 PM
venomhp's Avatar
any updates Im having a similar problem and its really starting to bother me
Old Nov 23, 2008 | 09:44 PM
nope not yet i'm waitin on a new bcm and then i'll let y'all know
Old Nov 23, 2008 | 10:14 PM
006rcsb's Avatar
what exactly is a bcm?
