Key Fob
Old Feb 1, 2012 | 07:40 PM
red4.8's Avatar
Default Key Fob
I have a 2008 sierra wt, is there any way to reprogram a key fob without going to the dealer. Don't want to pay 60 bucks..
Does anyone know if this is plug and play or is it only if your truck came with it from the factory.
Driver Information Center - Includes Instrument Panel Trim Plate - 2008 - Sierra 1500 - GMC
Old Feb 2, 2012 | 10:34 AM
Nope must bend over and grab your ankles no way around the dealer to program it.
Old Feb 2, 2012 | 10:40 AM
TXSZ66AVLANCHE's Avatar
First step, remove your hands from your ankles...
Insert Key and turn to ON position so you can access Driver Information Center
2. Press the vehicle information button until
PRESS TO RELEARN REMOTE KEY displays
3. Press the set/reset button until
REMOTE KEY LEARNING ACTIVE displays
4. Press and hold the lock and unlock buttons on the keyless remote at the same
time for approximatley 15 seconds. A chime will sound indicating that the remote is
programmed.
5. To program additional remotes at this time repeat step 4.
This vehicle can have a maximum of eight remotes programmed.
6. To exit programming mode turn key off and remove key.
Test remote(s).
Yes it will work for your truck even if not built from the factory with it.
Old Feb 2, 2012 | 11:05 AM
red4.8's Avatar
There is no PRESS TO RELEARN REMOTE KEY message, just miles, trip, oil life, trans temp, tire position
Old Feb 2, 2012 | 11:26 AM
La SS's Avatar
Try holding it
Old Feb 2, 2012 | 11:44 AM
Do you have RPO "AUO" in the glove box label?
Old Feb 3, 2012 | 08:57 AM
red4.8's Avatar
I will check today.
Old Feb 3, 2012 | 09:10 AM
red4.8's Avatar
I have AU3
AU3 Door locks, power
AU3 Door locks, power programmable
AU3 Locks, Power Door
AU3 Lock, Power Door, Electric
AU3 Lock Control Side Door, Electric
AU3 LOCK CONTROL SIDE DR, ELEC
Old Feb 3, 2012 | 09:35 AM
red4.8's Avatar
I see au0 is remote keyless entry, not sure why they would put power locks on with no keyless entry. O'well
Old Feb 3, 2012 | 02:56 PM
Can't do it on my 11 only a few vehicles get out here and there with the remote key learning feature activated. It is usually only found in fleet vehicles like police tahoes etc. all others must go to a dealer to use tech 2 to reprogram key transmitters.
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
dantheman1540
Nov 1, 2015 02:59 AM
GM1697
Oct 20, 2015 12:12 PM
Justin87gn
Sep 10, 2015 12:06 PM
