Headlight connector PN
Old Aug 26, 2011 | 08:48 AM
stevenc's Avatar
Default Headlight connector PN
Does anyone have the part number for the headlight connector (both high and low beam)?
Old Aug 26, 2011 | 06:49 PM
Steve-O-08's Avatar
Headlights are 9006 and HI's are 9005's you can pick up the pigtails at a local parts store.
Old Sep 1, 2011 | 03:37 PM
stevenc's Avatar
Thanks.
I just got done building a relay harness for the highs and lows for my truck.. Both high and low are on when the highs are turned on. Works great with hid's in both.
Old Sep 1, 2011 | 03:50 PM
Atomic's Avatar
I have a gauge for that
I did the same thing with a 10 cent 12v diode...
Old Sep 1, 2011 | 04:43 PM
TX Tahoe Z71's Avatar
+1
Old Sep 2, 2011 | 06:22 PM
stevenc's Avatar
My factory harness barely will run 1 set of HID correctly so the diode mod would not work. I had flickering, one not coming on etc. I am also pretty sure the 2002 is not a diode capable truck. Thanks tho...
Old Sep 2, 2011 | 11:48 PM
Parke10's Avatar
on the 02 you just cut and ground a wire. did it on my old roomates 02 for his HIDS
Old Sep 3, 2011 | 09:07 AM
stevenc's Avatar
I don't like to cut into my harness when possible. I needed to run a relay for both sets of hids due to power delivery issues so it was just as easy to make a harness run a diode in the new relay arrangement and have full voltage and amps to my lights .
someotherguy
Nov 8, 2017 06:46 PM
xtrooper89
Sep 21, 2015 06:03 AM
kalikid06
Sep 20, 2015 07:46 PM
kmcn47
Sep 17, 2015 01:12 AM
the owl
Sep 4, 2015 04:09 PM
