gps placement...
Old Jan 14, 2009 | 11:39 AM
BLKZ71's Avatar
Default gps placement...
I just bought a new eclipse double din w/ GPS. where's the best place to put the gps antenna? was thinking of stringing the wire through my 3rd brake lights and putting the antenna on the roof.. what are my options?
Old Jan 14, 2009 | 12:32 PM
BLK WDO's Avatar
that will be ur best option. the antenna needs full opening to work and fuction properly.
its either there or through the dash, up the water seal in the door and out right by the windshield. but most audio stores do the third break light to the roof cuz its less noticeable and can charge u out the *** cuz they have to take a lot out the cab to run the cord
Old Jan 14, 2009 | 03:30 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
x2^...i always liked to do it through the door though...just a lil less hassle
Old Jan 14, 2009 | 10:17 PM
BLKZ71's Avatar
well, nothing a coat hanger and electrical tape can't fish through to find the wire on the other side... I'll try that first.....Anyway, just cut out the din a little with the dremel to allow more room for the double din. I'll post a couple of pics after it's all wired up.
Thanks for the advice!
Old Jan 14, 2009 | 10:21 PM
Mangled03gmc's Avatar
Baltimore Whore
If it is anything like the one with the pioneer units, I went from under the dash, notch a lil place in the fuse cover, then another place in the weather striping at the front of the door, ran the wire threw it then glued it back up(weather strip) around the wire, placed the magnetic antenna on the top rail of the inner fender, under the edge hood, back by the hood hinges. You can't tell it is even there, even if you look, it works perfect...
Old Jan 19, 2009 | 11:47 PM
BLKZ71's Avatar
do ya'll know how to bypass the safety screen on these eclipse HUs?
Old Jan 21, 2009 | 10:51 AM
OneQwikSS's Avatar
ground the parking brake wire
Old Jan 22, 2009 | 10:39 AM
BigRedChvy355's Avatar
I stuck my gps antenna on the metal bar behind the radio mount and I have a full signal everywhere I go except for tunnels and the such.
Old Jan 22, 2009 | 11:53 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, I thought you could mount it under the dash, as long as it has a clean signal through the windshield. Factory GPS antennae are located on/in the dash?
dropkick13
Dec 1, 2007 11:30 AM
NORCAL STI
Dec 24, 2004 01:07 AM
z71tahoe
Aug 27, 2002 09:37 AM
