Factory HU to amp install
Old May 5, 2007 | 12:12 PM
drkblusierra's Avatar
Default Factory HU to amp install
I have my a mono amp and sub wired and ready to go... but since i want to use my factory head unit i a bit confused if there is something out there that will allow me to wire rca outputs off my stock HU, ive looked into the PAC aoem-gm21c
but cannot find anywhere that confirms this will work for my truck (02' Sierra non bose, single cd player) What other options do i have?? if i use a line level convertor what color wires am i looking to tap into? thanks
Old May 5, 2007 | 05:20 PM
UnrthdxDream's Avatar
that connector looks just like the one that came off the back of my 2002 factory unit... but i havent been behind the dash in a while...
Old May 6, 2007 | 12:00 AM
i bought this today...
what are the speaker wire colors that i need to tap into?
Old May 6, 2007 | 12:23 AM
you tap into both channels of either of the rear speakers... should be the purple and green wires? dont remember off the top of my head... just trace em back form the speaker
Old May 6, 2007 | 12:38 AM
found this, on well another forum, so its the rear speakers to tap into huh, what sould i tap the remote wire into?
94-02 trucks and suvs
Radio 12v orange + radio harness
Radio Ground black - radio harness
Radio Ignition yellow(dk green in the later modes with RAP) + radio harness
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on might be orange
Power Antenna pink +
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
Old May 6, 2007 | 12:53 AM
53bowtie's Avatar
put amp turn on wire to yellow(dark green)ignition wire and tap any of the speaker wires for signal check out this thread so i dont have to type it all over again
https://www.performancetrucks.net/fo...d.php?t=391666
Old May 6, 2007 | 12:57 AM
10-4 thanks!
Old May 14, 2007 | 06:20 PM
xsports33's Avatar
i've used those before with some success, but a common problem that i kept hearing about was it was causing the subs to "pop" even when the HU was turned off. Didn't know exactly what was causing it, but when we switched to using all RCAs the problem went away.
thunder550
Oct 8, 2015 04:53 PM
Greatdivider
Sep 9, 2015 09:52 AM
slowlsx
Aug 10, 2015 05:33 PM
Dezert1500
Jul 30, 2015 02:51 PM
