a/f and oil pressage guage
Old Feb 13, 2007 | 11:49 PM
navy_ao_05's Avatar
Default a/f and oil pressage guage
what do i need for them to work i have the guages and some wires are still hooked up
back of oil guage
back of a/f
thanks all
Old Feb 20, 2007 | 01:54 AM
navy_ao_05's Avatar
anyone?
Old Feb 20, 2007 | 02:21 AM
Blown02Sierra's Avatar
+12v, ground, wideband 02 sensor and controller, and either a bung in your oil pan or a connection to your oil pressure sensor.
Old Feb 20, 2007 | 02:50 AM
navy_ao_05's Avatar
where do i get this wideband 02 sensor and controller and bung in your oil pan or a connection to your oil pressure sensor?
and yes i edit and copied it
Old Feb 20, 2007 | 06:54 PM
Which gauges are these? You will need some sort of wideband such as the innovate lc-1 or plx (sm-a4?). You can get these all over the internet. Green Light Motorsports on here sells the lc-1. This will give a reading of your a/f ratio. W/o forced induction and/or tuning, you dont really need to monitor your afr. On the oil pressure, doesnt your truck have an oil pressure gauge? It's not all that necessary either. Does the oil press. gauge have only wires, or is that an oil line? If its electric, the factory oil pressure sensor is on the pass. side of the block either right above, or on the oil pan. I dont know which wire would be reference or output, and i dont know what the reference voltage is on that system, nor what the voltages relate to in psi. If it's mechanical, then I would forget about it. It's only easy and necessary on turbo vehicles IMO.
Old Feb 21, 2007 | 04:16 AM
navy_ao_05's Avatar
they are autometer guages
Old Feb 21, 2007 | 05:28 PM
yeah, which autometer? Is the oil pressure digital?
Old Feb 24, 2007 | 03:39 AM
navy_ao_05's Avatar
ultralite i think and no it has a needle and electric
lukn4trbl355
Oct 21, 2015 11:19 PM
Lthompson
Oct 2, 2015 12:45 AM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
Lthompson
Sep 21, 2015 07:06 PM
