a/f and oil pressage guage
Which gauges are these? You will need some sort of wideband such as the innovate lc-1 or plx (sm-a4?). You can get these all over the internet. Green Light Motorsports on here sells the lc-1. This will give a reading of your a/f ratio. W/o forced induction and/or tuning, you dont really need to monitor your afr. On the oil pressure, doesnt your truck have an oil pressure gauge? It's not all that necessary either. Does the oil press. gauge have only wires, or is that an oil line? If its electric, the factory oil pressure sensor is on the pass. side of the block either right above, or on the oil pan. I dont know which wire would be reference or output, and i dont know what the reference voltage is on that system, nor what the voltages relate to in psi. If it's mechanical, then I would forget about it. It's only easy and necessary on turbo vehicles IMO.
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Sep 25, 2015 12:36 PM
