digital gauge install
Old Feb 21, 2010 | 10:35 PM
zittman's Avatar
Default digital gauge install
Got a question about hooking up the dimming part of the gauge on my 00 Silverado. I need to know which wire to hook up to dim the lights on the gauge when my headlights come on. I know which wire to hook up from the gauge just need to know what wire to hook up to on the switch or where ever else in the dash from the gauge????? It says:5. The orange wire needs to be connected to the positive side of the parking lights. The easiest way is to tap into the wire on the parking lights assembly or you can also connect it at the headlamp switch. This is optional. If it is not hooked up then the gauge will simply not dim when you turn on your headlamps. Any help would be great!!
Old Feb 22, 2010 | 01:59 PM
zittman's Avatar
Anybody have an idea?
Old Feb 22, 2010 | 02:52 PM
SSmikeSS's Avatar
I took a voltage meter and tested the wires under the dash near the switch. I just looked for the wire that read 12 volts+/- when the lights were on and didn't read anything when the lights were off. I can't remember where I spliced the wire in. I may have just spliced right in the middle of the wire.
What kind of gauges did you get, Dakota Digital?
Old Feb 22, 2010 | 04:14 PM
brandon6.0's Avatar
hey take a test light and nip your wire back just a tad and test it at low or dimest and turn it to brighter by the switch while testing it and it should make your test light brighter as the lights get brighter. This is what worked for me when i added the under dash lights to my truck. i think its a light green colored wire.
thunder550
Oct 8, 2015 04:53 PM
hartinclay
Aug 3, 2015 07:03 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
