Automatic Electric Cutout Remote w/ Alarm button???
Old Sep 22, 2009 | 07:32 PM
coles1189's Avatar
Default Automatic Electric Cutout Remote w/ Alarm button???
So I have 2 Summit E cutouts wired to one switch in my dash.
I have an autopage alarm w/ un used accessory buttons on the remotes
I bought a window roll up / roll down module for the alarm
was wondering if I can wire my window module to the alarm, and to the cutouts instead of the window...
that way when i press the button on my remote the cutouts open, press again and they will close...
The only thing i realized is the cutouts dont stop until you release the button, so do the window modules have timers??
it is an Xpress module...
Any help please
thank you
Old Sep 22, 2009 | 07:58 PM
charcoal03silvy's Avatar
Ummm, why???
Old Sep 22, 2009 | 09:08 PM
coles1189's Avatar
so i can remote start my car and open and close the cutouts too
Old Sep 22, 2009 | 09:23 PM
Ask a tuner......
Old Sep 22, 2009 | 10:20 PM
Black'Rado's Avatar
I wouldn't use the window module. The alarm has negative trigger outputs so you can hook the grounds from your cut outs to say trunk pop output and hook constant power to your cutouts. Then after you remote start the truck hit trunk pop and it should open the cutouts
Old Sep 22, 2009 | 10:44 PM
coles1189's Avatar
sounds like itd work...
what about closing ?
and also will the cutouts keep trying to open or will they stop?
I dont want to burn it up
Old Sep 22, 2009 | 11:25 PM
Dewey's Avatar
certain alarms carry more functions than others. go talk to any alarm installer. most of the mecp installers should be able to tell you what alarms this would and would not work with... my viper alarm can be programmed to do just about anything, you just need to know what to do.
Old Sep 23, 2009 | 12:14 AM
OmarR's Avatar
The solution is going to depend more on the operational function of the cutouts
Do you have a link to the install/wiring diagrams for them?
Old Sep 23, 2009 | 12:18 AM
coles1189's Avatar
link is:
http://cgi.ebay.com/AUTO-POWER-4-WIN...ht_4946wt_1167
would i be able to install something like this without the window module?
Old Sep 23, 2009 | 01:58 AM
skolman91's Avatar
not a alarm expert here but i imagine something like that cuts giving power when the window circuit breaker flips. if thats the case you would have to use a circuit breaker with your cutouts. second guess is it cuts power when theres a amp or volt spike, that could possibly work but would be bad on the motors imo. why even mess with it, unless u find a way to remote control the throttle with a scanning red led bar in the front and some sound effects.. now that could be fun
edit: looked at ur link a little and looks like that thing is just a big circuit breaker with ground side power control and goes one by one closing the windows. find one for a two winder and let us know how it goes. but they wont open at the same time, one by one as it states..
