Air/Fuel Gauge
Old Apr 18, 2008 | 06:25 AM
Biggsw784's Avatar
Default Air/Fuel Gauge
I got a autometer air/fuel ratio gaugefor my 2006 cc with a 5.3 and was curious what wire I needed to tie into on the o2 sensor?? What is the best way to do this?? Thanks for any info...
Old Apr 18, 2008 | 08:13 AM
blue2003ls's Avatar
Is it a wideband O2? If so I think they use a proprietary O2 sensor and you will need a bung to be welded into the mid pipe before the cat.
Old Apr 18, 2008 | 08:41 AM
Biggsw784's Avatar
well its the factory o2?? so not sure if that helps. how should i find out??? thanks
Old Apr 18, 2008 | 09:37 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Don't bother hooking up a gauge to your factory narrow-band sensor, it's a waste of time and $$ unless all you want is a light show.
Old Apr 18, 2008 | 09:54 AM
Biggsw784's Avatar
so i need to buy a wide band senor and have a bung weld in???
Old Apr 18, 2008 | 10:11 AM
Melissa@NelsonPerformance's Avatar
FormerVendor
We supply them here!
PLX AFR Wideband
I have them available NOW $269.00 plus shipping
black or white face
thanks
melissa
Old Apr 18, 2008 | 10:27 AM
fastnblu's Avatar
I sure hope not. That'd suck if I can't use whatever brand on my Autometer wideband. I need to hook mine up; now I gotta check myself.
Old Apr 18, 2008 | 12:27 PM
thunder550's Avatar
High on diesel fumes
Most wideband kits use the Bosch wideband O2 sensor. It's actually an OEM sensor from a Volkswagen.
Old Apr 18, 2008 | 03:13 PM
fastnblu's Avatar
That was what I thought. Bosch does the o2 for our trucks, then GM slaps the ACDelco name on the bag, if I remember right.
Old Apr 18, 2008 | 03:35 PM
blue2003ls's Avatar
That's better than the $90 Summit wants for the Autometer brand wideband O2 sensor. I havn't been able to find an alternative yet but mine still works for now.
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
zblee
Sep 17, 2015 07:58 AM
kmcn47
Sep 17, 2015 01:12 AM
