3 subs, which amp?
Old Sep 9, 2008 | 07:08 PM
lo&sloSierra's Avatar
Default 3 subs, which amp?
will a kicker zx750.1 run 3 comp 10's fine? or is there another amp i should use?
Old Sep 9, 2008 | 09:21 PM
SeegsRST's Avatar
u should buy my kx1200.1 it would power those alot better
Old Sep 10, 2008 | 06:45 PM
53bowtie's Avatar
the black cone with yellow stitching comps will be just fine on that amp. They are only 150w rms if i remember right. Just remember, with 3 it is going to be a wierd ohm load at the amp so it will not do the same power as it is rated for at 4 and 2 ohm.
Old Sep 11, 2008 | 12:34 PM
blueflamed03's Avatar
if you run it at 2 ohm perfect, KX12001 is too much for three Comps.
Old Sep 11, 2008 | 01:20 PM
larsy87's Avatar
apple bottom jeans
Whats the ohms on those subs?
Old Sep 11, 2008 | 01:38 PM
valleyperformance's Avatar
i have 3 JLaudio w3's wired to 1ohm with a db drive platinum series 900x1 and couldn't be happier with the sound
Old Sep 11, 2008 | 05:35 PM
53bowtie's Avatar
He could run 2 ohm if they are single 4 ohm subs. That would give him 1.34 ohms which would be closer to 2 ohms after rise.
Old Sep 11, 2008 | 06:08 PM
true, 1.34 or 2.66, depening on coil config.
Old Sep 11, 2008 | 10:48 PM
53bowtie's Avatar
course if he rant the kx1200.1 at 3 ohms (2.66) instead of 2 it wouldnt be as bad if you are carefull with the gains.
Old Sep 12, 2008 | 08:47 AM
KX12001 does max power at 1 ohm tho, not 2.
