Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Water pump pulley just flew off!!!!
Old Oct 26, 2007 | 06:49 PM
  #21
ranwalk's Avatar
Originally Posted by CHEVRACER83
Damn I Forgot.. I Was Thinking Old Small Block..... No Bolts... Press Fit.... So You Probably Just Wore The Press Fit With The Belt Being Too Tight....
Question ..... What Setup Are You Running??? That You Can Adjust Tension?
Stock tensioner, the belt was just so short I had to pry,twist,and stretch it to get it on. It had the tensioner completly collapsed it was so tight.
Old Oct 26, 2007 | 09:22 PM
  #22
Dock Rocker's Avatar
Originally Posted by ranwalk
Yep, something is missing
Ahhh Houston we have a problem!
Old Oct 27, 2007 | 12:53 PM
  #23
ranwalk's Avatar
Well, got it fixed. Two problems though, the belt I had at home is the same length as the one that came off. I was thinking it was a little longer, so I still gotta get another belt. Problem two is the 160 degree thermostat I was using will not fit in the new water pump so I am using the one that came with it, Its probably a 195. Not sure if thats really a big deal or not.
Old Oct 27, 2007 | 01:05 PM
  #24
CHEVRACER83's Avatar
195 ISNT NECESSARILY "BAD" I MEAN UNLESS YOUR HITTING 230-240.... THEN ITS A BIG DEAL...
GIVE ME THE NUMBER OFF THE BELT AND ILL GET YOU A NUMBER FOR WHAT YOU CAN USE
Old Oct 28, 2007 | 02:10 PM
  #25
BigKID's Avatar
Randy, If it is the new style thermo where the thermo is seperate from the housing, I have a 180 that came with my KB kit I can send you.
Old Oct 28, 2007 | 02:38 PM
  #26
nonnieselman's Avatar
Hey man... I got a lil trick i learned from mr John Oconnor..
It includes a BB... and then i drilled out the lil check ball.... it runs at 180*... only cost me... nothin..
I have a few Waterpumps layin around the house also.
Old Oct 28, 2007 | 04:54 PM
  #27
ranwalk's Avatar
Thanks Kenny, I just went ahead and ordered a 160 from Jegs. Now I gotta make up my mind on what to do for a belt.
Old Oct 28, 2007 | 09:31 PM
  #28
BigKID's Avatar
No problem Randy. Hope everything works out for you and you start haveing some good luck with the truck.
Jonathan... You may want to ask Mr. O'Connor where he learned that trick.
murderedSS
27
Oct 12, 2015 11:13 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Justin87gn
Sep 10, 2015 12:06 PM
InsaneDomestics
Sep 10, 2015 05:32 AM
mr03silverado
Sep 2, 2015 11:43 PM
