Water pump pulley just flew off!!!!
#23
Well, got it fixed. Two problems though, the belt I had at home is the same length as the one that came off. I was thinking it was a little longer, so I still gotta get another belt. Problem two is the 160 degree thermostat I was using will not fit in the new water pump so I am using the one that came with it, Its probably a 195. Not sure if thats really a big deal or not.
#24
GIVE ME THE NUMBER OFF THE BELT AND ILL GET YOU A NUMBER FOR WHAT YOU CAN USE
#26
It includes a BB... and then i drilled out the lil check ball.... it runs at 180*... only cost me... nothin..
I have a few Waterpumps layin around the house also.
#28
No problem Randy. Hope everything works out for you and you start haveing some good luck with the truck.
Jonathan... You may want to ask Mr. O'Connor where he learned that trick.
murderedSS
27
Oct 12, 2015 11:13 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
mr03silverado
Sep 2, 2015 11:43 PM
