Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Water pump pulley just flew off!!!!
Old Oct 26, 2007 | 04:08 PM
ranwalk's Avatar
If I remember right you have ALOT of tension on your belt maybe all that side-loading pressure on the pulley is what killed it?
Thats exactly what i'm thinking happened. That belt was TIGHT!!!!! Was just a matter of time. Let that be a lesson kids, dont overtighten your belt
Old Oct 26, 2007 | 04:17 PM
CHEVRACER83's Avatar
Did The Bolts Back Out Or Did The Hub Section Rip Off The Pulley??
Old Oct 26, 2007 | 04:18 PM
Btw Good Excuse To Go With An Electric W/p
Old Oct 26, 2007 | 05:32 PM
Dock Rocker's Avatar
He has a damn good point randy.
Old Oct 26, 2007 | 05:35 PM
ranwalk's Avatar
Too much money, got a new stocker sitting in my office as I type. Gonna be putting it on tomorrow
Old Oct 26, 2007 | 05:39 PM
nightrunner's Avatar
Mr. Obvious
consider yourself lucky in the situation, mine came off(still have clutch fan), and when it did it shredded the belt, shattered the fan shroud, bent the water pump shaft, and when it SHOT INTO MY RADIATOR! it left a nice sized hole in it, so needless to say, i didnt drive it too far.
btw, i had a stock 4.8 +programmer and exhaust at the time and went over 6krpms in manual 1st and then it popped.
Old Oct 26, 2007 | 06:00 PM
DAMN IVE SEEN BALANCERS ON MY OLD STROKER SMALL BLOCK SEPERATE AND TAKE OUT MY EFANS.... IT ACTUALLY SOUNDED LIKE A BROKE A ROD FROM THE METAL CLANKING... I CAN LAUGH ABOUT IT NOW BUT IT SCARED THE HELL OUTTA ME WHEN IT HAPPENED... I WAS RUNNING AGAINST A JETTA WOT AND ALL OF THE SUDDEN IT JUST WENT BAM!!!
Old Oct 26, 2007 | 06:23 PM
KY_BOB's Avatar
Damn, sorry to hear about your bad luck.
... or did it break the water pump shaft? That's what I'm wondering?
ranwalk's Avatar
Yep, something is missing
Old Oct 26, 2007 | 06:43 PM
Damn I Forgot.. I Was Thinking Old Small Block..... No Bolts... Press Fit.... So You Probably Just Wore The Press Fit With The Belt Being Too Tight....
Question ..... What Setup Are You Running??? That You Can Adjust Tension?
