Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Habit I'd like to BREAK!!!!!
Old Dec 9, 2008 | 07:15 PM
  #41
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
think so. :sad
Old Dec 9, 2008 | 07:29 PM
  #42
StrokerAce03's Avatar
So just clean it up and a couple of new pistons and it'd be ok or is there something deeper? If its just pistons just pick up some 4.8 flat tops; I've been dying to see someone try this.
Sucks about the problems man.
Old Dec 9, 2008 | 07:36 PM
  #43
white1's Avatar
Wont work
Old Dec 9, 2008 | 07:40 PM
  #44
Originally Posted by white1
Wont work
Why not? Its a 5.3 isn't it? The pin heights are the same between the two piston sizes (or from what I've seen).
Old Dec 9, 2008 | 08:19 PM
  #45
00Silv4.8's Avatar
**** THAT SUCKS! I was hoping for more results from you guys running ballistic bricks
sad to see it toast man... 5.7? or 6.0???
Old Dec 9, 2008 | 08:39 PM
  #46
white1's Avatar
From what I understand (and makes sense) If both the 4.8 and 5.3 have the same bore (truth) then the stroke is different. Meaning either, the 4.8 has shorter rods, or the piston pin is at different heights. If you use the 4.8 pistons, they will protrude the top of the block at the top of the stroke.
Old Dec 9, 2008 | 10:35 PM
  #47
litreddevil's Avatar
Banned
man that sucks bad i got that extra motor i told you can have it but you have to take it all.
Old Dec 9, 2008 | 11:00 PM
  #48
nonnieselman's Avatar
Dang that does suck man!!
i think your transmission just got mad at your engine, thats all.
Old Dec 10, 2008 | 07:35 AM
  #49
95ImpSS's Avatar
I always thought they had different cranks. Based your comment... assuming the cranks were the same, shorter rods would lessen the compression with piston not rising as close to the heads as a 5.3L with (possibly) longer rods. The comment below does not seem to support the rod difference theory. Anyone have any more info on this??? Dealer part comparison???
Originally Posted by CarCraft
The displacement difference between the 4.8L and 5.3L engines is created with the stroke. The 4.8L engine uses a 3.27-inch stroke crank, while the 5.3L engine has the common Gen III V-8 3.622-inch stroke crank.
CarCraft Article... Interesting Info
Old Dec 10, 2008 | 08:55 AM
  #50
TurboGibbs on here I think said that the pin heights were the same. The 4.8 has longer rods and a shorter crank. Here's an interesting thread on it:
https://www.performancetrucks.net/fo...ht=4.8+pistons
Sorry to ***** up your thread
