Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
everyone with 2001 6.0 or knowledge
Old Dec 28, 2006 | 01:42 AM
Default everyone with 2001 6.0 or knowledge
Will an 01 LQ4 bolt up to my 4l60e? I have gotten mixed ideas whether it was 2001 or 2002 where the LQ4's mated with the 60e's. Please tell.
EDIT*** And if it does NOT fit, is there anything I can do within reason to get it to?
Old Dec 28, 2006 | 01:43 AM
$thatguy$'s Avatar
hmmmmmm i dunno but im guessing they will
Old Dec 28, 2006 | 02:16 AM
DBYRD's Avatar
use the 5.3 harness and pcm it should be ok may need a tune tho...
Old Dec 28, 2006 | 03:37 AM
thunder550's Avatar
High on diesel fumes
You should be fine. Check to see if it has aluminum heads. 99 and 00 were the ones that had iron heads and the different length crank that would cause problems.
Old Dec 28, 2006 | 08:11 AM
Nick™'s Avatar
if it has aluminum heads your good. take the flex plate off, it will be for a 4L80e, then remove the spacer on the crank. After that put your original flex plate on and install.
Old Dec 28, 2006 | 09:46 AM
yea it's a short block so I won't know about the heads but I think I trust this guy and IF it doesnt fit....he is local so I can make a quick drive to tell him what's up. So my 5.3 flexplate will also work once I remove the spacer...this is good news.
Old Dec 28, 2006 | 09:55 AM
litreddevil's Avatar
Banned
when you take the flywheel off the spacer most of the time comes with it then that will tell you what year it is if no spacer then the crank will needed to be change are you will have to space it out the thinckness of the spacer if will work but i will not do it again i did it on a friends truck and he is still driving it so yes it works
Old Dec 28, 2006 | 10:03 AM
alright well it has no fly wheel so I am going to trust this guy that its an 01 and go on my merry way
SloSVO
Nov 22, 2020 07:34 PM
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
