Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Audio Help Asap!!!!
Old May 23, 2008 | 09:42 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
Default Audio Help Asap!!!!
alright guys might not be the right place to post this but idc i need to know ASAP what is the wire off the stock head unit that i would use as a remote to tap into...i've got a full system everything is ran except the remote i ****** forgot please help me out ASAP!!! thanks for everyones input!
Old May 23, 2008 | 09:55 PM
smoke03's Avatar
I would just find a switched 12 volt because Im not sure.
Old May 23, 2008 | 10:26 PM
yellowdemon327's Avatar
pretty much any wire on it that goes live when you turn the key on
Old May 24, 2008 | 01:23 AM
OneQwikSS's Avatar
alright so right now i've just got the remote runnin off the orange (12V) constant ...so the amp is always on right now...what i think i'm gonna end up doing is just running a wire up to the fuse box in with something else that's not a constant probably just up to like an ignition fuse or somethin idk i'll figure it out but is there really no accessory wire back there in that harness? i ran my test light through every hole gm startin with some weird things lol
Old May 24, 2008 | 01:49 AM
RandomHero's Avatar
why not just switch the remote wire to one of the other wires on the head unit. It will save you the trouble of running the remote wire to the battery.
Old May 24, 2008 | 02:03 AM
TXsilverado's Avatar
wrap it around a post on the ingition fuse in your interrior fuse box. that will turn your amp on and off when you start and shut down the truck.
Old May 24, 2008 | 02:05 AM
RandomHero's Avatar
Mine is just spliced into one of the wires on my head unit. I've had it like that for 3 years with zero problems. I'll have to see which one I spliced into sometime.
Old May 24, 2008 | 05:17 AM
viciousknid's Avatar
Where's the Beef?
That's what most installers do. Just get a test light and see which wire comes on with the key. Splice into it and call it a day. A lot of after market stereos have a blue or blue/white remote wire.
I think on the factory system it's a pink wire.
Old May 24, 2008 | 05:26 AM
Where's the Beef?
Here you go. PK is pink btw
¹ The factory radio does not have an ignition power lead (it turns on via the OG data line in pin #1). An interface must be used to retain the factory data bus system and door chime.
² The PK wire triggers the Bose amplifier. To retain the Bose system when an aftermarket radio is installed, the amp remote lead of the new stereo must be connected in-line with this wire.
Old May 28, 2008 | 03:35 AM
OneQwikSS's Avatar
THANKS FOR ALL THE HELP!!!!!
however...turns out i blew the sub...voice coils are fried haha lol aw well looks like i'm goin with an addictive audio sub...slammin' sierra baby
http://www.addictiveaudioinc.com
Pimpinpete
43
Dec 22, 2017 08:13 AM
CD82
Oct 23, 2015 07:32 AM
GM1697
Sep 28, 2015 08:28 PM
maxspeed05V
Sep 23, 2015 10:48 AM
MOBBN
Sep 22, 2015 08:07 PM
