What a badass build! Major props and can't wait to see it completed!
Thanks brother, it's coming slowly but surely. Just don't have enough time to really spend on it. Trans should be done soon, and should be seeing some dyno numbers as soon as I replumb the coolant crossover and get the snout back.
Scored a set of Centerline Stingrays for $400. Need some lovin but nothing some wet sanding and polishing can't cure. New pulley is on and working on linkage setup right now. Gotta make some kind of bracket to get the geometry correct and keep the cable from pulling at an angle.
