Lets talk 6l80!!!!
Old Jul 2, 2016 | 12:15 PM
  #71
24245965 is camaro part number according to rockauto
Old Jul 2, 2016 | 01:21 PM
  #72
tgui's Avatar
Originally Posted by 07Softail
I made the 3-5-R drum holder from a pair of old Vice grip clamps and a steel band. and I use a large worm clamp for pump alignment same as 4l80 tool. It works perfect and cost $3.00 at the hardware store.
RT
I did the band thing on my 4l80e pump.
Old Jul 2, 2016 | 01:26 PM
  #73
The gm version of the pump alignment tool for the 6l80 is metal ring that has a step on one side to fit over the lip of the conterter housing and center the pump, using the bolt in the side of it.... I have been able to bolt the pump down before forgetting about the alignment tool, and it was damn near centered, hardly moved when i put the alignment tool on it! if they had put another dowel in the pump it probably wouldnt have been an issue never understood the point of one locator dowel...
Old Jul 2, 2016 | 02:35 PM
  #74
Theisbis the kent moore gm tool
This is an aftermarket version that you can see the lip if you look close enough
Old Jul 2, 2016 | 09:24 PM
  #75
07Softail's Avatar
Yeah I would rather have the snap ring pliers over that tool being that the worm clamp works perfect for me.
RT
Old Jul 2, 2016 | 10:02 PM
  #76
About the snap ring, everything i see says 9:00 from bottom of case, my trans the snap ring was at 12:00. did they change it from early to late production??
Old Jul 2, 2016 | 10:06 PM
  #77
07Softail's Avatar
I have seen them all over the place, didn't know there was a specific spot to clock it at though.
RT
Old Jul 2, 2016 | 10:59 PM
  #78
According to the assembly instructions in SI the proper position is the 9:00 position....
Old Jul 5, 2016 | 11:46 AM
  #79
Anyone who is interested, 24248008 is the part number for the complete friction module for the 6l80, does not come with any steels just fiber clutches...
Old Jul 5, 2016 | 04:13 PM
  #80
Do you have part numbers on those 2 converters or are they the same number?
RT
Well....Just slightly irritated the parts guy, lol!! apparently caprice, camaros and 1500 trucks all use same converter... 17804387
