Problem with Billet Grille
Old Mar 22, 2005 | 11:19 PM
trucksleeper's Avatar
Default Problem with Billet Grille
I went to try to put my Grille on and it seems like it stiks out a little bit I was just wondering if I am the only one with this problem or not. Please give me some sort of feedback on this.
Old Mar 22, 2005 | 11:21 PM
F8L Z71's Avatar
Lots of issues on why it can stick out.
If it is a new truck and using a bolt-over grill eyou have to trim some of the stock grille away to set it back farther inside the shell. Without any detial there are too many reasons why it might not fit right.
Old Mar 22, 2005 | 11:23 PM
graystepside's Avatar
what year is your truck? did you buy a bolt over grill or a grill where you had to cut out the stock inserts?
Old Mar 22, 2005 | 11:25 PM
The truck is a 2000 model and it is a bolt over it seems like it is hitting the stock grille behind it.
Old Mar 22, 2005 | 11:28 PM
F8L Z71's Avatar
Yeah, that's what i figured it was. We install them all the time and they usually do that.. IMO I would take the time to actually cut out the stock grille and install it that way. It's much cleaner IMO. If you are happy with the way it is now then simply mark the spots with some tape or something, remove the grille and grind that high spots on the stock grille till it fits flush.
Old Mar 22, 2005 | 11:30 PM
Well I think it is a bolt over a buddy of mine got it for free from his work and it just come in a box with no instructions.
Old Mar 22, 2005 | 11:37 PM
where are the screw holes on the grill? there should be either a tab with 2 holes on each side or 2 tabs at the top and bottom bottom of each grill. if you have these the easiest thing to do is cut out the factory inserts
Old Mar 22, 2005 | 11:42 PM
I have the one where there are two tabs at the top and bottom on each side but the tabs on the bottom are different from the tabs on the top.
Old Mar 22, 2005 | 11:45 PM
ok you will need to cut out the factory inserts. the easiest way is to take off your whole grill and then cut out the inserts. it is not hard to do. i will try to find the link i was given to show me how to do mine.
Old Mar 22, 2005 | 11:51 PM
this was the site i was given by a fellow member to see his install and it reall helped me out. click on the truck, then on installs. http://www.geocities.com/carart1/mysites.html
OHsixLS3
Sep 25, 2015 11:20 AM
The Sgt
Sep 24, 2015 08:06 AM
TAPyvehc93
Sep 17, 2015 10:10 AM
Roody0209
Sep 17, 2015 09:06 AM
sprayed99
Sep 14, 2015 12:36 PM
