New Wheels on!
Hey. I really like my new wheels! Its Fizan tires 275/45/20 and Boss333 20x8.5 wheels. Today finally I put on it. Took test drive. IT kinda scare me when I brake it. It real shake on brake pedal. I not sure where it cause??? Tell me why brake pedal start shake alittle. Anyway when I go faster move the steering the back make more flex and loose like not tight when you curve. Even I have sway bar on back. Give me any idea.
If I remember right he's deaf. FYI.
You going to lower it any? If not I would have gone275-55. fills the gap a little better. Did you have them mounted and balanced at a shop? Might be off balance causing the shaking.
Yes, the tires are brand new and wheels too. Just got them yesterday. The balance already on it. Not sure if it due of rotors or balance again? The balance is stick label on wheels. Not tabs on lips. You know what I mean? I not know what the word call.
Ah ok then those will fill up nicely. Those little stick on weights do a pretty good job of staying on, but I'd have them rebalanced (they should do it for free I'm hoping). If that doesn't solve it then I'm at a loss.
Truck looks awsome. I have same wheel and tire setup. I had mine Static Balanced at a Discount Tire. Does your truck pull to the left or to the right any? If its a brake rotor the truck will pull to the opposite side of the bad rotor. I think its a bad rotor by the way you discribe it.
