How much is it to put air bags in 02 chevy?
Old Mar 18, 2010 | 03:45 PM
SILVY303's Avatar
Question How much is it to put air bags in 02 chevy?
i have an 02 chevy single cab with 22s it is only leveled with shackles... i want to put air bags on it....i dont kno much about the total price after installation so please any estimates.......ps how much for a 4 6 drop
Attached Thumbnails How much is it to put air bags in 02 chevy?-img_0637.jpg   How much is it to put air bags in 02 chevy?-img_0635.jpg
Old Mar 18, 2010 | 04:58 PM
BLK WDO's Avatar
when it comes to air suspension.......you get what you pay for. you can find shops that do it for $2500 but more than likely you will have air line leaks or the bag mounts are not right, or something rubbs on the bag and blows out. ect ect. (**** they should check before the truck goes out the door)
and GOOD shop will charge anywhere from $3500-$6000. or you can go the expensive route and go to a shop like extensive and get a full frame built.........but that is REAL pricey
do research and see what shops do what kind of work. where are you located? i know some fair share of good shops
Old Mar 18, 2010 | 05:27 PM
03 True Fire's Avatar
depends on what shop you go to for the kit, or if you get them to do it, ekstensive out of houston does the best work i have ever seen, but dont expect to save money, quite pricey but they do sick work. but if you just buy their kit and do the work yourself, youd maybe take a grip or two off depending on what you can get hooked up with. if you dont know how to weld or fabricate..dont do it yourself
Old Mar 19, 2010 | 02:04 PM
SILVY303's Avatar
wow that is pricey i was lookin to spend 2g topz..and im in okla city
Old Mar 19, 2010 | 03:31 PM
jg53's Avatar
go with the drop then and save some money
Old Mar 19, 2010 | 03:42 PM
GueroRCSB's Avatar
just do a drop...
Old Mar 19, 2010 | 04:06 PM
williebones's Avatar
do a drop then when you have enough money take it to NFAMUS Air Suspension in Mansfield TX
Old Mar 19, 2010 | 06:09 PM
BLK WDO's Avatar
im gettin little shop of horrors to do mine when the time comes.
nfamus is a good shop! goo **** rollin out of their place
Old Mar 21, 2010 | 11:58 AM
ws6ls1's Avatar
Ekstensive FTMFW. Bill and his guys are quite possibly the greatest in the world at what they do. I am biased because Im friends with him and his guys but anybody that can take a $90,000 truck, cut it in half and section a piece in then put it back together and have a GM executive say "How did you get a triple cab Kodiak, we dont even offer one of those?" is a bad ****. There are tons of other shops that do awesome work and a few of them do some work that could be Ekstensive quality, but Bill always seems to do something that one ups everyone.
Old Mar 21, 2010 | 01:31 PM
RandomHero's Avatar
Asking how much it costs to bag a truck is like asking how much it costs to make a truck "fast"
One could realistically do a full setup for $2000, but if you're asking this question you aren't going to be able to come close to that. At $2000 you would have to fab up your rear link setup from scratch and do all the fabricating yourself. You'd have to run just cups on stock arms up front, 3/8" valves and run a single compressor/tank setup.
Now realistically I would expect to spend at least $4000 and that's on the low side. Running a KP 6 link, dual compressors, drop spindles for the front, tubs, notch cover, air management, and 1/2" quality valves is going to run you at least $4000 in just parts alone and most likely closer to $5000 when everything is said and done.
shawn96gmc
May 17, 2016 04:15 PM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
