HELP Shaving roll pan
Old Mar 3, 2010 | 09:52 PM
2000silvrx81's Avatar
Default HELP Shaving roll pan
Has anyone that has shaved their roll pan spot welded it from the back of the bed instead of having the spot weld visible to the eye if your standing at the back of the truck. i know its not going to matter after i do the body work just curious if anyone has done this before. Im also going to have to do some fiberglass work to get the bed even all the way down to the roll pan. Let me know what you think and any pictures would be much appreciated.
Old Mar 3, 2010 | 09:59 PM
You want to weld it full on the finish side and metal finish it down to smooth metal. You don't just spot weld it, then fill the crack.
Also you don't want to put fiberglass on it, metal and fiberglass have different expanding and contracting characteristics. Unless you're talking about kitty hair filler. But you still need to fully weld and metal finish it for good results.
Old Mar 3, 2010 | 10:13 PM
Mangled03gmc's Avatar
Baltimore Whore
Exactly
Just showing one side, but you get the idear
Fill it as best you can with weld, grind it down as smooth as you can.. Then fill with heavy glass the green stuff(marglas) sand and block the hell out of it, then skim it again with a lighter glass.. Repeat, untill it is flat.. A few pics of mine(before it got HIT AGAIN ) Basically by the time it is finished there is hardly any glass in the area.. You will never get the metal perfect, so some glass needs to stay..
Old Mar 4, 2010 | 07:26 PM
whitegmc2002's Avatar
what is the name brand of the roll pan and how did it fit^^^
Old Mar 4, 2010 | 07:37 PM
Baltimore Whore
SIR MICHAELS.. The fit was very well..
Old Mar 4, 2010 | 07:54 PM
alright, sounds good to me, i hate the fact that the gap between the pan and tailgate is so much on mine.....oh well, thatnks for the input everyone!
Old Mar 8, 2010 | 11:14 AM
ILuvJDM's Avatar
damn that looks good
Old Mar 9, 2010 | 09:04 AM
you should be able to pull it up a little and when you weld it bend the sides to match the bed. You can get it pretty close, just got to remember when the tailgate drops it's curved so keep testing it.
Old Mar 9, 2010 | 08:32 PM
sounds good man, been keeping up with your thread, bad *** build. i could do it to a non electronic vehicle but no computer equipped ones!
SloSVO
Nov 22, 2020 07:34 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
lxcoupe
Sep 25, 2015 12:36 PM
