Headlight Mod for $1
Old Feb 16, 2012 | 07:25 PM
  #251
AKlowriderZ71's Avatar
11 Second Hall Moniter
Old Apr 8, 2012 | 10:24 AM
  #252
BlewSilverado's Avatar
Has anyone done this mod for the fog lights to come one with the low beams on a nnbs? I had this on my 04 and it worked like a champ. I have a 2012 now and it has a different configuration. I did find where someone was able to get the lows to come on with the highs but not the lows with the fogs.
Old May 18, 2012 | 08:52 PM
  #253
MISTERIO's Avatar
Bump i have a 2012 to
Old Jun 20, 2012 | 11:26 AM
  #254
bigcountry119's Avatar
Can someone post up a picture of this mod using the interior connector pinout method? As in an actual picture of the connector with diodes installed and where it is located under the dash
Old Jun 20, 2012 | 09:22 PM
  #255
5speedsilverado's Avatar
added fogs to mine, i hardly ever use my highs with this setup, the only time i do is when im on the freeway out here that is literally through the middle of the desert and has no street lights
Old Oct 10, 2012 | 10:03 PM
  #256
nonnieselman's Avatar
Got a question. On the 99-02, if one was to ground the yellow wire. Do the fogs work since the lows are on?
Old Oct 10, 2012 | 10:13 PM
  #257
slonlow2000's Avatar
No, it still doesn't work like that. I just grounded the yellow wire on mine this past weekend when I installed my hids. When I was testing the brights on the hids it still kills my fog lights.
Old Oct 11, 2012 | 05:06 AM
  #258
TIM Z's Avatar
11 sec. Truck Mod
Yeah bump again, I want highs, lows, and fogs on my 2000 to work.
Can never find an answer. Did this mod to my dmax years ago and it's great.
Old Oct 11, 2012 | 08:23 AM
  #259
Could always do a relay off the high beam? that way when the highs come on, the lows automatically come on.. and then the fogs come on. hum..
i might try it tonight.
Old Oct 11, 2012 | 06:54 PM
  #260
_zebra's Avatar
makes children cry
i've got a relay setup for the high-4 on my 2000 corvette, and it still don't keep the fogs on with the lows, and i think it's the same kind of setup - the BCM controls the fog power based on high-beam power
the truck ain't got factory fogs (i added my own on an independent circuit), so i can't tell you on there.
