Headlight Mod for $1
Old Mar 12, 2009 | 01:21 AM
  #151
baron's Avatar
Originally Posted by ohohsilverado
i have an '00 and thats exactly what i wanted to do...change to orange bulbs all the way across.
the ls1tech link is dead now... anyone know how to do this?
Old Mar 12, 2009 | 01:34 AM
  #152
klep2024's Avatar
Just did this mod to my 06..it was cake! The worst part is cramming the diodes in the lack of space next to the wiring. I jumped my lows to my highs and my fogs to my highs, then jumped my fogs to my lows. I couldnt see jumping my fogs to my DRL's, cuz why would i ever need fogs during the day? Anyone know which prong the turn signals is? And could you jump the drl's to that and make the whole assembly light up?
Old Mar 19, 2009 | 03:29 AM
  #153
klep2024's Avatar
Sry to revive this thread again but can you just use the same method to jump the drls to the lows? Or for the drl's to be on with the parking lights do you just hafta splice into the turn signal wires? If so what wires would you hafta splice together?
Old Mar 19, 2009 | 08:42 PM
  #154
klep2024's Avatar
Nvm..i tried it and it works..The drl's also still function as drl's but i jumped them to the lows with the diode method so the entire lower light bar lights up when the lows are on. And since i did the other diode jumps, when the highs are on, every light comes on
Old Mar 19, 2009 | 11:45 PM
  #155
budhayes3's Avatar
PT's Slowest Truck
That must look good, pics?
Old Mar 20, 2009 | 02:05 AM
  #156
klep2024's Avatar
I'll post them up tomorrow..all i can take right now are cellphone pics and that wont do it justice at all!
Old Mar 24, 2009 | 05:13 AM
  #157
alanderson1978's Avatar
Switches are a great idea!
One thing to keep in mind is that these additional relays are all being powered by one pin in the BCM. ex: If you have HI --> LOW --> Fogs --> DRL, the BCM pin for HI's is pulling in 4 relays instead of just one, and it's not really designed to carry that load.
That being said, I've had Hi's to Low's to Fogs for about 3 years with no trouble.
Old Mar 25, 2009 | 10:14 PM
  #158
Naranjas HD's Avatar
are this the ones u all use for the 01 style trucks or just ground the yellow wire? and will this afect if u have hids on high and lows?
Old May 13, 2009 | 09:23 PM
  #159
fastlt1's Avatar
12 Second Club
I want to keep my lows on when I switch on my highs. But I have HID lows. Will this cause a blink in power?
Old May 13, 2009 | 09:35 PM
  #160
viciousknid's Avatar
Where's the Beef?
shouldn't. the diode just triggers them to come on. they still draw power the same way they would initially.
