Getting closer to painting the hood
Old 07-05-2008, 04:00 PM
  #41
KySilverado's Avatar
First coat of epoxy sealer is on. Wet the booth floor. Go over the panel with wax grease remover. Washed it with dawn earlier. Tac cloth the panel. Spray a couple test paterns. Shoot it.
The test cardboard
Little stand in the booth.
Old 07-05-2008, 04:16 PM
  #42
2nd fastest 5.3 ECSB
trever1t's Avatar
heck that's a better booth than some of the paint shops have around here
Old 07-05-2008, 04:42 PM
  #43
Sealer done. 2 coats. Directions say least possible for coverage. Waited 20 minutes went had a look. Couple small pieces of lint in it. Light scuff pad and those are gone. So far so good. Keeping my fingers crossed.
Old 07-05-2008, 04:45 PM
  #44
For those that may want to know. Devilbliss Finishline gun. 1.8 tip with the epoxy. 20 psi at the gun.
Old 07-05-2008, 04:55 PM
  #45
SPAM HUNTER
2005 Silverado's Avatar
Looks good to me so far! I think you found your natural unknown talent?
Dustin
Old 07-05-2008, 06:29 PM
  #46
2K Urethane primer is on. Three coats. Tack cloth between coats to clean up the over spray. So far I am stoked. Going to let it dry over night. Block/wet sanding tomorrow.
Old 07-05-2008, 06:31 PM
  #47
Dustin
I do like doing it. It is hard, dirty, work. I might have a talent for it. We'll see after the color and clear spraying.
Old 07-05-2008, 07:05 PM
  #48
onebad03's Avatar
looks like you may need to overlap your coats more to prevent the "tiger stripping" when you lay down your base. it may just be shadows but its hard to tell.
Old 07-05-2008, 07:47 PM
  #49
Yeah it does have some striping in it. Overlap more as in closer together? I was trying to do the standard 50% overlap.
It was really hard to see the primer going down. I could hardly tell I was even laying anything down a few time. I might break down and get couple extra lights for the base coat.
Old 07-05-2008, 08:37 PM
  #50
onebad03's Avatar
yeah your right with the 50% overlap. its cool with the primer because your blocking it plus with your base being a different color youll be able to see better. looking good so far though. BTW i work at a body shop and i use the same gun at home, the boss buys SATA at work but they are way too expensive for messing around at the house.
Quick Reply: Getting closer to painting the hood
