front inner fender rubs
Old Feb 20, 2008 | 11:23 AM
2001CamaroGuy's Avatar
Default front inner fender rubs
I have 285/50/20s on the front with a 2" drop (belltech spindles) and sometimes on hard bumps, the outside rubs the upper inner fender. I was thinking of taking my air hammer and just "massaging" (ie: hammer it like nuts ) to make some room but thought I would ask if anyone has some better ideas. It isn't bad and kind of reminds me of the good old BFH (Big F*ing Hammer) mod that always has to be done on F-bodies when we would put wide tires on the rear.
Old Feb 20, 2008 | 01:34 PM
00Silv4.8's Avatar
for the front I'd say get some smaller tires. Quick and beatingless fix IMO
Old Feb 20, 2008 | 02:40 PM
LowBlack99's Avatar
I get some rub on my 4/6 with 275/45/20 but mostly on dips in the road so I try to miss them as much as I can, the rear is a different story!! I did the BFH mod and rolled them in cause they cut my tires. Shouldn't have that problem with your 2/4.
Old Feb 20, 2008 | 05:23 PM
My problem is the same as yours (big dips in the road) except since I used drop spindles instead of lowering sprigs, I still have the soft stock springs (ie: my front will compress more than yours on the same bump).
Old Feb 27, 2008 | 11:48 AM
LowBlack99's Avatar
I still have the stock springs up front, justa 4in. drop arm and stock spindle's.
thunder550
Oct 8, 2015 04:53 PM
Lamartian92
Sep 10, 2015 09:27 PM
Lamartian92
Aug 21, 2015 01:43 PM
vipergtrdj
Aug 6, 2015 10:19 PM
