fog light mod (i tried searching)
Old Mar 12, 2009 | 12:51 AM
baron's Avatar
Default fog light mod (i tried searching)
i cant figure out how to make so just my foglights can be on without the headlights on, or i can keep them on with the high beams
Old Mar 12, 2009 | 01:05 AM
charcold-bowtie's Avatar
https://www.performancetrucks.net/fo...+headlight+mod
There ya go
Old Mar 12, 2009 | 01:19 AM
viciousknid's Avatar
Where's the Beef?
for a 99 tho you'll have to read in there a ways.
I think you have to cut a wire on the fogs for the 99-02
baron's Avatar
thanks i'm on pg 4 so far and havnt seen anything...
also my drls dont work ever... would a relay be out?
Old Mar 12, 2009 | 06:43 AM
BLK WDO's Avatar
do u have a dome over ride button???
if so, push it in and out 4 times...should cut the DRL and low/high beams off but will still be able to use fogs.....
i think
Old Mar 12, 2009 | 10:20 AM
05GTO6SPEED's Avatar
on the 99 and maybe the 00 the dome overide does not work, the only thing i know to do is before you crank it but the e-brake on one click then crank it. the lights will be off then when you want to turn them on release the e brake.
Old Mar 12, 2009 | 10:24 AM
aksz71's Avatar
mine is a 02 and i have to press the dome light 4 times and then it cuts my lights off and then turn the fog lights on.. then if you want the lights back on just push the dome 4 more times and they come back...
Old Mar 12, 2009 | 08:46 PM
baron's Avatar
i think
that doesnt work
Corvette454l88
Sep 1, 2016 01:24 AM
markyrgv
Aug 16, 2015 11:50 PM
pupi305
Aug 13, 2015 03:48 PM
RoidedSS
Aug 11, 2015 11:51 AM
Ketis
Jul 23, 2015 12:37 PM
