Color match grille and wheel offset ?s
Old May 17, 2008 | 02:44 PM
flippincamaro's Avatar
Default Color match grille and wheel offset ?s
WHere can I get a paintable grille for a 2000 up tahoe? Will the basic work truck grille work? Also what offset you guys running on your 22s I am looking at a set of 22 X 9.5 +30 OFFSET Does this sound right? Thanks for any help
Sorry if in the wrong forum
Old May 17, 2008 | 05:28 PM
Neverdone's Avatar
I just painted the stock grill on my 01 Silverado minus the center chrome bar. Cant say much for the wheels. I just ordered a set of 22x9.5 with +28 offset for my truck. I will let you know how they fit when I get them in a couple weeks. Not sure if it will help you though as they are for a pickup..
Old May 18, 2008 | 12:49 AM
Yea Im wanting to paint the whole grille and I know the chrome piece will peel the paint easy. Thanks for the reply
Old May 18, 2008 | 01:11 AM
RandomHero's Avatar
How low do you plan to go with the truck? What size tire are you planning on running. Those rims should be fine for the most part unless you're going low.
Old May 18, 2008 | 12:03 PM
budhayes3's Avatar
PT's Slowest Truck
I've seen "ready for paint" aftermarket grilles on ebay, as well as chrome...
Old May 18, 2008 | 06:44 PM
Im not going lower than I am now. I had 22s on it but didnt know the offset. I had 305 40 22 on it and the new wheels will have the same size tires. I like the meaty look with those tires on 22s. It rubbed a lil in the front when I turned all the way. But no biggie.
Old May 19, 2008 | 12:34 PM
VroomVroom's Avatar
If you're not going any lower, that offset spec should be fine. Just a thought, 285/45's look great as well, and tend to be a little better in fending off rub. In my experience they ride a little better and track better as well.
A bit of scuffing on the grille shell, followed by a good adhesion promotor (and maybe a flex primer...consult with your paint pro), and you'll be set for painting. I had my old grille shell done and never had any issues.
Old May 19, 2008 | 12:46 PM
thunder550's Avatar
High on diesel fumes
Is the W/T grille with the gray center bar paintable?
Old May 19, 2008 | 01:41 PM
Thunder550 from what I have found out yes it is. And thanks Vroomvroom for the info.
Corvette454l88
Sep 1, 2016 01:24 AM
WhoAteMySoup
Aug 20, 2015 09:52 AM
Staggered 02
Jul 27, 2015 02:53 AM
Ketis
Jul 23, 2015 12:37 PM
