Carbon Gauge Bezel: please help with install!
Old Dec 29, 2003 | 11:35 AM
ChevyTrukRacer99's Avatar
Default Carbon Gauge Bezel: please help with install!
When using these stick on things, how do you separate the factory plastic pinch weld between the factory bezel and the gauge window? can i heat it and nudge it with a razor? or should i just trim the back piece off?
thanks in advance for any and all help!
Old Dec 29, 2003 | 06:27 PM
KeukaZ71's Avatar
do you have a picture of what you are trying to install? i might be able to help you out better. i put on a carbon fiber dash overlay kit. i took the entire instrument cluster out. then i took the clear plastic "window" off the cluster so i could access the gauge needles. did you get that far yet? are you trying to get that black plastic bezel off?
Old Dec 29, 2003 | 10:44 PM
How did you take the plastic off, that's where i'm stuck. I got the cluster out and all and got the whole shield with the clear plastic window off, but how do you take the clear window off?
Old Jun 14, 2005 | 12:31 AM
Searching4Sierra's Avatar
i just cut the plastic out
thunder550
Oct 8, 2015 04:53 PM
hartinclay
Aug 3, 2015 07:03 PM
carid
Jul 24, 2015 05:00 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
