Carbon Gauge Bezel: please help with install!
When using these stick on things, how do you separate the factory plastic pinch weld between the factory bezel and the gauge window? can i heat it and nudge it with a razor? or should i just trim the back piece off?
thanks in advance for any and all help!
do you have a picture of what you are trying to install? i might be able to help you out better. i put on a carbon fiber dash overlay kit. i took the entire instrument cluster out. then i took the clear plastic "window" off the cluster so i could access the gauge needles. did you get that far yet? are you trying to get that black plastic bezel off?
hartinclay
Aug 3, 2015 07:03 PM
carid
Jul 24, 2015 05:00 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
