anyway to turn the headlights off?
Old Aug 12, 2005 | 04:32 PM
SBChevrolet's Avatar
Default anyway to turn the headlights off?
I was woundering if there anyways to keep the headlights OFF at night... I would like to know if theres anyways I can turn my lights completely off and only have my parking lights off after dark... like you can on a older truck
Old Aug 12, 2005 | 04:37 PM
white1's Avatar
Push the dome light button 4 times.
TWANKYDEUCE's Avatar
hit the dome light button 3 or 4 times and the headlights go off
Old Aug 12, 2005 | 10:49 PM
awsome thanks guys... wheres the sensor for the headlings anyways?
Old Aug 12, 2005 | 10:57 PM
It dident work... Im guessing yall were talkin about the dome overide botton? BTW my truck is a '99 if that matters
Old Aug 12, 2005 | 11:16 PM
graystepside's Avatar
i do not think it works on a 99. tried that in my truck a while back and it didn't work.
Old Aug 13, 2005 | 05:14 AM
TXsilverado's Avatar
sensor is on top of your dash. its a little black bubble lookin thing
Old Aug 13, 2005 | 06:03 AM
JimS's Avatar
My 01 manual had instructions. Push the dome override 4 times. Maybe your manual has instructions?
Old Aug 13, 2005 | 10:31 AM
budhayes3's Avatar
PT's Slowest Truck
The dome override trick won't work on 99's unfortunately...I bypassed the photodiode with an led right at the bcm which is right under the left side of the dash. Got the led at Radio shack for less than 2 bucks and it took about 5 minutes to do. My headlights are now fully manual with no auto function, but that's how I like it. I can take a look in my service manual and find out which wires I bypassed if you'd like.
Old Aug 13, 2005 | 10:45 AM
budhayes3's Avatar
PT's Slowest Truck
I just snipped the grey and white wires and used an LED, you could use a regular diode or a resistor I guess, but I went with an LED because I assumed that it would have the same resistance as the ambient light sensor. It worked for me
The BCM is right under the steering column. If you remove the lower dash finish panel it's right in the center. It's not necessary to remove the panel, but it gives you more room.
