anyone got pics of a 285/60/17 on a factory 17x7.5 wheel?
Old Jan 12, 2011 | 10:16 AM
BlackGMC's Avatar
Resident Retard
Default anyone got pics of a 285/60/17 on a factory 17x7.5 wheel?
post them up if you got them...
Thanks
Old Jan 12, 2011 | 03:36 PM
maxh's Avatar
Ive got 275 55 17s. Whats your drop on your truck?
They were good on my 4/6 drop rcsb. I got them so i could go 5/7
Old Jan 12, 2011 | 04:55 PM
dlt76028's Avatar
I thought the stock 17's were 7" wide? they should look close to alex's wide *** tires, except his wheels are 8"
Old Jan 12, 2011 | 05:02 PM
dlt76028's Avatar
heres a 285 on 8".
Old Jan 12, 2011 | 08:43 PM
BlackGMC's Avatar
Resident Retard
I thought the 16's were 7, the 17's were 7.5 and 18+ were 8 wide... I may be wrong thou...
Old Jan 17, 2011 | 10:29 PM
SlvrSierra4.8's Avatar
Yea, all GM 17's are 7.5" wide. Here's a couple old pics I had saved on my computer.
285/60/17's
I am in need of a new set of tires also and have been strongly considering the 285/60's. Just can't confirm how they will ride or wear on that narrow of a rim....... I know all the tire manufacturer's of that size spec a minimum of an 8" rim
Old Jan 18, 2011 | 11:08 AM
BLACKND's Avatar
Slvr, that looks good on the black RCSB. Was that yours? I know all suggest an 8" wide on 285's, but I see it done all the time in larger A/T & mud tires so who knows.
Have always wondered about the 285-60-17's though on stockers though, came close to going that route with a previous truck.
Old Jan 18, 2011 | 11:48 AM
custm2500's Avatar
Ph.D. in HUBRIS
With a taller sidewall you can/ want to run a narrow wheel. The shorter the sidewall the closer you need your wheel and tire to match so you don't get irregular wear. You should be just fine with a 7.5 wheel. I prefer no bulge in the sidewall but you should have very little with your planed set up.
Old Jan 18, 2011 | 11:52 AM
BlackGMC's Avatar
Resident Retard
Oh well i ordered some 275s hankooks. Those 285s do look good thou
Old Jan 18, 2011 | 04:36 PM
custm2500's Avatar
Ph.D. in HUBRIS
What kind of hankook? The 275 will fit a little bit better anyhow.
