22" wheel offset for 4/6 drop
Old Dec 25, 2006 | 01:05 PM
onebad96T/A's Avatar
Default 22" wheel offset for 4/6 drop
What wheel offset do i need for my Crew Cab thats droped 4/6, i will be using a 265/35/22 tire.
Thanks Lance
Old Dec 25, 2006 | 02:55 PM
nightrunner's Avatar
Mr. Obvious
how wide are they ?
02bluestepside is pretty good with wheel/tire and suspension setups
Old Dec 25, 2006 | 03:37 PM
02BlueStepside's Avatar
A 265/35/22 is definitely the best tire choice. Offset/backspacing will depend on the width of the wheel though, do you have any in mind?
Old Dec 25, 2006 | 06:38 PM
All that i have looked at are 9 1/2" wide, I like those Boss 313's they come with 40mm offset, some others only offer 18mm offset. Just need a little direction..
Old Dec 25, 2006 | 07:16 PM
Ok whats the diffrence between backspacing and offset? One website list a 22 x 9 1/2 with +20mm offset and 6.0 backspacing. Would this work?
Old Dec 25, 2006 | 07:19 PM
Mr. Obvious
i think you are going to need a 6.5 inch backspacing on a 9.5 inch wheel 6 inches on 9 inch wheel, 5.5 on a 8.5 inch wheels and so on and so forth i think
Old Dec 25, 2006 | 08:48 PM
The above are close, and you might be able to get away with them, but add .5" backspacing to all of them and you shouldn't have to worry about clearance issues. For a 22x9.5, 6.5 backspacing would be close, probably have to roll the rear fender lips.
Check out this site, it tells you a lot of things such as backspacing/offset. http://www.rsracing.com/tech-wheel.html
Old Dec 28, 2006 | 01:09 AM
TWANKYDEUCE's Avatar
go with the +40 or +20 offset. I have 20mm and they tuck but rub, but thats when I drop it down. I ran a 4/6 for a while and 20mm offset with no problems but I had to trim my fender lips
Old Dec 28, 2006 | 10:22 AM
Im thinking about going with a Driv Moonshadow wheel that is 22x9.5 w/ 30mm offset and 6.5 back spacing. But do i have to stick with the 265-35-22 tire or can i go wider?
Lamartian92
Sep 10, 2015 09:27 PM
Lamartian92
Aug 21, 2015 01:43 PM
WhoAteMySoup
Aug 20, 2015 09:52 AM
Codog
Aug 16, 2015 08:23 PM
Porscharu914
Aug 10, 2015 10:57 PM
