Yet another turbo build...
Old Nov 15, 2015 | 06:18 PM
  #391
smokeshow's Avatar
Mod with training wheels
Oh man, that's good stuff. We really need a lesson in nonlinearity around here.
Old Nov 15, 2015 | 06:21 PM
  #392
George C....'s Avatar
Formerly ScreamingL
If you want smart ***...we can meet up and ill show ya slips with dyno sheets to support each other
Numbers were dynojet sae
Or my crewcab...276 rwhp 89mph
540 rwhp 113 mph
So thats hair under 1mph per 10rwhp
So examples of 3400lbs.....4500lbs....4700lbs....5600lbs
Old Nov 15, 2015 | 06:38 PM
  #393
smokeshow's Avatar
540 rwhp 113 mph
My point is that doesn't hold true. Maybe I'm just different...I don't care at all for 'rules of thumb'... It feeds too much into misinforming people. Refer to my previous example... An additional 300hp isn't going to get a 150mph 4800lb truck to go 180mph in the 1/4.
Old Nov 15, 2015 | 10:12 PM
  #394
1FastBrick's Avatar
Custm2500's Rude Friend
Wait, What?????
Old Nov 15, 2015 | 11:01 PM
  #395
AKlowriderZ71's Avatar
11 Second Hall Moniter
Lmao, why do you guys try to argue/reason with somebody who already knows everything??
Old Nov 16, 2015 | 05:29 PM
  #396
GMCtrk's Avatar
Can anybody comment on a potential trans issue please.
Now with the new tighter torque converter, my shifts are significantly softer (which I don't like, I like firm shifts you feel in the seat). I thought a tighter converter was supposed to make the shifts more pronounced?
When I was removing the trans, I did notice when I removed the main harness plug that there was trans fluid inside the connector. Seems like it was leaking around the pins. I haven't had any actual trans leak but there must have been some seepage there. Could ATF on the pins be affecting the line pressures at all? Trans is working as it should, but I haven't actually done a WOT shift yet, just a bunch of 3rd gear pulls. So I don't want to shift it under power if it's not getting the right pressure and burn it up. Thanks.
Old Nov 16, 2015 | 06:19 PM
  #397
03sierraslt's Avatar
Put a gauge on it.
Old Nov 16, 2015 | 07:14 PM
  #398
Vortec350ss's Avatar
Check your logs for calculated input torque and see if its lower now. You may be referring to lower shift pressure cells.
Old Nov 16, 2015 | 07:18 PM
  #399
GMCtrk's Avatar
It's noted under regular driving, no boost (before or no) so everything should be the same.
Old Nov 16, 2015 | 09:57 PM
  #400
interesting. It was just a thought. I guess it could still hold true though. If you are driving with less throttle input it could be referencing lower trans pressure cells. Try playing with that table a little
