Yet another turbo build...
Old Dec 26, 2012 | 08:34 PM
  #31
GMCtrk's Avatar
Originally Posted by Pollo432
Looking good. You torque the pan to spec or gave it till it felt snug? Just made a 1000mi trip with my kb kit at 12psi. Got 400mi out of a full tank.
Torqued to spec. 18 ft lbs on the M10 bolts and 106 inch lbs on the 2 M8 bolts.
Old Dec 27, 2012 | 09:09 PM
  #32
GMCtrk's Avatar
Cold side almost completely mounted. Perfect fit on the drivers side. Passenger side is a butch with all the coolant hoses. Do yourself a favor and drain the coolant before hand. I will shorten the water pump to radiator hose tomorrow and finish everything up. If i can get my hands on a oil dipstick tube it should be fired up tomorrow
Old Dec 27, 2012 | 09:31 PM
  #33
Pollo432's Avatar
Running a boost controller? Make sure you get the dipstick in all the way. Thought I had mine in all the way in and it would leak oil, thought it wa my oil pan so took it back off for nothing. I put a little grease on the dipstick o-ring and slid right in, no more leaks. Everything looks good.
Old Dec 27, 2012 | 09:35 PM
  #34
GMCtrk's Avatar
No boost controller as of now. Its the jgs 50mm wastegate with the lighest spring. Should be like 7 lbs or so. We will see.
Ill be sure to get the dipstick in good, thanks.
Old Dec 27, 2012 | 11:29 PM
  #35
UnVmy5.3's Avatar
do you have anymore pics of the cold side? im wanting to try and use the clutch fan
Old Dec 28, 2012 | 08:43 AM
  #36
GMCtrk's Avatar
This pic should show you everything you need to know about KB's pipe fitment. Ill be honest, i was a little concerned about this atuff fitting when i mocked it. But once i actually put it together fitment was perfect. The bead rolled ends on the pipes is a plus too.
Old Dec 28, 2012 | 07:11 PM
  #37
GMCtrk's Avatar
Cold side finalized. Took some time and some cussing but got it all on. Fit is tremendous.
Also got the crossover pipe on, then couldnt fit the 4" DP from the top or bottom. Then realized pulling the tire and fender liner will give me the room i need. It was dark by then though, so tomorrow.
Gonna try and get an oil dipstick tube from GM tomorrow since 2 junkyards refused to sell me one today. Finish the DP and wastegate connection and finalize the vacuum tubing and some wiring odds and ends. It should be alive tomorrow.
Old Dec 29, 2012 | 08:23 AM
  #38
silver-mod-o's Avatar
Hunt&Fisherator
Keeping the MAF??
I'd replace that spliced together hose with one piece. No reason to have that there just waiting to leak at this stage in the game, it would cost a couple bucks, take all of 5min to fix and probably save a leak and some headache down the road...
Old Dec 29, 2012 | 09:28 AM
  #39
GMCtrk's Avatar
Originally Posted by silver-mod-o
Keeping the MAF??
Yeah, I'll be using the MAF for the time being. The way I looked at it, even if I want to go to SD in the future it won't be a problem just to keep the MAF in the tubing and relocate an aftermarket IAT sensor to the EGR block off plate.
Regarding the oil line I think you're right. Still just pissed off I cut it too short.
Old Dec 29, 2012 | 01:07 PM
  #40
Hunt&Fisherator
Or just use the MAF as your IAT and have the option of going back for whatever reason if you'd choose later on.
