Yet another turbo build...
Old Nov 10, 2015 | 04:18 PM
  #341
BlackGMC's Avatar
Resident Retard
i don't remember the brand i had but it was about $100 i think. I could touch mine briefly after a long drive. I could not keep my hand on it for forever but then again it did not burn me touching it. For example trying to swap out plugs after running.
my previous blanket just cooked itself to death and became hard and crusty..
  #342
Atomic's Avatar
I have a gauge for that
It wasn't for me, but my setup always seemed to run incredibly hot. I think I had a PTP at one point. The last one I used was a $50 ebay one I think.
You will want to wrap that line as much as you can...let me put it this way, my wrapped turbo pipes and turbo with a blanket on it melted the plastic fender liner that was a good 6" away from the heat source.
Old Nov 10, 2015 | 04:22 PM
  #343
GMCtrk's Avatar
the line is wrapped with multiple layers of cool tape and you've got to remember, it's been running like this for 3 years now and the t6 housing isn't that much bigger than the t4. I did have to bend the line over some more for extra clearance however I'm not terribly concerned about it rupturing.
Old Nov 10, 2015 | 05:04 PM
  #344
BlackGMC's Avatar
Resident Retard
So is the t6 80 alot or slightly bigger than the t4 75? Meaning physical room it takes up?
Old Nov 10, 2015 | 05:07 PM
  #345
GMCtrk's Avatar
It's bigger, no doubt about it. The turbine housing is bigger and it's longer with the turbo sitting more forward than the t4 unit. But it's not a dramatic difference. The t4 is already much bigger than the stuff from precision, turbonetics, etc.
Old Nov 10, 2015 | 05:10 PM
  #346
GMCtrk's Avatar
Not the same angle, but you can compare with the compressor covers which are identical for all intents and purposes...
Old Nov 10, 2015 | 05:11 PM
  #347
George C....'s Avatar
Formerly ScreamingL
turbo blanket is a consumable but ive put my hand on the blankets after dyno pulls
Old Nov 10, 2015 | 08:12 PM
  #348
GMCtrk's Avatar
i think i'm gonna install a boost gauge and maybe get the speedhut afr gauge
I've been well against any visible gauges in the cab but I really need to know what's going on when I'm trying to tune this setup.
My argument against gauges has been that if the motor is going to blow it's going to happen before you can react anyways.
Old Nov 10, 2015 | 09:47 PM
  #349
Vortec350ss's Avatar
Interesting logic...
Old Nov 10, 2015 | 11:01 PM
  #350
smokeshow's Avatar
Mod with training wheels
He's not wrong though lol.
