Winter project(s)
Old Mar 24, 2013 | 12:38 AM
  #181
smokeshow's Avatar
Mod with training wheels
I can command the shift with key on engine off and hear the clicks. But its unresponsive while driving.
Old Mar 24, 2013 | 12:45 AM
  #182
Atomic's Avatar
I have a gauge for that
Since it is relatively easy, try using the segment method...the newest hpt beta allows you to do it without sending in your file to support. Just have to remove your relay and hook up the iss, which is useful for analyzing the converter anyway. As far as why the relay isnt working for you...are you sure you hooked it up right? This is with the original pcm and not the e38 right?
That alternative is of course the trans is messed up...
Old Mar 24, 2013 | 12:51 AM
  #183
AKlowriderZ71's Avatar
11 Second Hall Moniter
Still have to send the file to HPT support for a segment swap...
Old Mar 24, 2013 | 12:58 AM
  #184
Atomic's Avatar
Negative ghost rider, the newest beta (at least, possibly less recent versions as well) have an option in the program to change the transmission type. Yes it does work, and yes it fixes that issue of the converter unlocking at 0% tps.
I changed from the relay method to this method when I swapped converters a few weeks ago.
Old Mar 24, 2013 | 01:07 AM
  #185
smokeshow's Avatar
Do you have the reference for wiring for the iss and using the hpt segment swap? Also, since my trans was originally a 4wd, the front speed sensor is blocked off..
Old Mar 24, 2013 | 02:19 AM
  #186
What beta version are you using? Mine has the TCC tables for keeping the converter locked, but no way of swapping segments or identifying a trans swap. I haven't seen it on the HPT forum either.
I feel left out!
Old Mar 24, 2013 | 03:26 AM
  #187
Tydriver's Avatar
Looks good man, hopefully when you get it dialed in it will give you years of enjoyment.. I hope to borrow a couple of your ideas (and other ones off this forum from other contributors) to build my truck.. I have a l'il 4.8L RCSB as well..
As far as the 2nd gear thing, that's a typical limp mode for the 80e. I believe you are correct in suspecting the controller is at fault. I had a buddy that built an 80e for a GMC Syclone and it was stuck in 2nd gear for a while too.. Ultimately he determined that it was a controller issue. I keep hearing about "the relay method" but I haven't done any reading on it so I have no pointers on that, his ended up being a wiring issue with the controller he was using at the time (non LS1 PCM). The good news is, the guy beats the ever-living-**** out of that truck on a regular basis and the transmission is just laughing at the 550hp it lays down.. I think you will worry no more once you get it sorted.
Good luck,
Old Mar 24, 2013 | 03:55 PM
  #188
oakley6575's Avatar
Originally Posted by AKlowriderZ71
I feel left out!
Me too. I've never heard of this?
Old Mar 24, 2013 | 04:01 PM
  #189
Atomic's Avatar
Im using 2.23.867
All there is!
  #190
ltr450ryder's Avatar
I feel left out!
When I updated mine it has a bar that has like 4-6 different trannys on it to select
