Walledition-New Project: Boost/Turbo-Fuel/Return System, Build
Old Jun 5, 2017 | 11:39 AM
  #141
kbracing96's Avatar
Then get the 275/60-15. They are a tad shorter and narrower. SHould still look good on your truck and they hook! lol
Old Jun 6, 2017 | 02:03 AM
  #142
Blown06's Avatar
8 Second Truck Club
Yeah get those and stretch them over a 12" wheel.
Old Jun 6, 2017 | 10:25 AM
  #143
walledition's Avatar
My wheels are 15x10
Old Jun 6, 2017 | 12:44 PM
  #144
BigKID's Avatar
Do you require a DOT stamped tire? If not you may look into the Pro Drag Radial and the Pro Bracket Radial. Both are available in a 29.5/10.5R15 which is equivalent to your current size. Hoosier also makes a 295/65/15 drag radial which works really well and has a DOT stamp.
Old Jun 6, 2017 | 07:00 PM
  #145
GMCtrk's Avatar
The old et streets should be enough tire to rip your rear end out.
How is the track prep?
Old Jun 12, 2017 | 11:20 AM
  #146
I dont need DOT, thanks i´ll look into them
Old Jun 12, 2017 | 11:26 AM
  #147
The track has been great and the best ive been is 1.73 but usually im in the 1.80-90´s, but never consistent, im sure theres something missing in my suspension, i just ordered viking double adjustable shocks from atomic see if that does the trick, i set the two step lets say to 3500 rpm and make 10 psi of boost then i leave it hooks-front suspension goes up and falls right back on its face then rear goes up in smoke
This is my suspension right now:
Front:
-2" lowered with spindles
-swaybar removed
-driver side has a 3/4" spacer to correct that the driver side was lower
-cheap monroe shocks
Rear:
-4" lowered with shackles and a small bracket that sets the front side of the leaf spring higher
-Shocks relocated
-rancho 9 position single adjustables
-selfmade tractionbars wish should be exacly the same as caltracks
-mickey thompson ET street radial
Old Nov 6, 2017 | 04:25 PM
  #148
Got some new parts for the truck, its time to upgrade to something better then a stock g80 so i got a eaton limited slip 19590-010, basic install kit and new tires 275/60-15 MICKEY THOMPSON ET STREET PRO DRAG RADIAL
Install start tonight if u got any advise con changing the LSD its appreciated
Attached Thumbnails Walledition-New Project: Boost/Turbo-Fuel/Return System, Build-2.jpeg   Walledition-New Project: Boost/Turbo-Fuel/Return System, Build-1.jpeg   Walledition-New Project: Boost/Turbo-Fuel/Return System, Build-3.jpeg
Old Nov 6, 2017 | 04:32 PM
  #149
lxcoupe's Avatar
The carrier preload shims won't be the same for the G80 vs the Eaton. Somewhere in my build thread I listed the exact shims I ended up with on my Eaton Trutrac. It was always 100% silent. Stock 3.42 gears with the original ring gear transferred over to the Trutrac. I didn't remove the pinion gear or change the pinion shims.
Old Nov 6, 2017 | 04:45 PM
  #150
i was planning on using the same ones if they look good, im glad u bring this up, i will keep the pinion as it it aswell, i´ll look that up in your build thread, btw did u use new bearing or the ones from the stock g80?
thank you
