Walledition-New Project: Boost/Turbo-Fuel/Return System, Build
Old Mar 24, 2016 | 01:16 PM
  #121
Byrdman11's Avatar
Thanks man for the info I needed.
Old Mar 24, 2016 | 10:07 PM
  #122
UnVmy5.3's Avatar
killer job on those cal tracs
Old Apr 5, 2016 | 03:14 PM
  #123
walledition's Avatar
Thank you, if i had known how much time and money would go into them i would have bought them but now im happy with them
Old Apr 5, 2016 | 03:29 PM
  #124
Update:
Installed the belltech 3/4" front lift spacer #34931 on the driver side, driverside used to be 6/8" lower in the front now its 1/2" higher with 1/4 tank of gas and without me in it
In the rear driverside used to be 11/16" lower now its 1/2" higher
So im happy with that now
Wasnt sure if they go on the lowerside of the spring or upper, installed them on the lower
Old Apr 5, 2016 | 03:37 PM
  #125
Update:
Installed 8733 MSD Two step, at 3500rpm i made 3.5-4.5psi of boost, now with the two step at 3500rpm it makes full boost (10-11psi) in just over 2.5 seconds
Video:
20160405_124949_zpsoz2gawep.mp4 Video by greensss | Photobucket
Old Apr 30, 2016 | 02:00 AM
  #126
With all the talk about weight here latley i decided i would find a local scale since our track doesnt have one
2005 singlecab stepside
6.0/4l80e/14bolt
Bogarts (15x10 rear/17x7 rear)
Sprayed in bedliner
Removed spare tire/mounting bracket, jack
Removed front swaybar
Traccion bars
Turbokit
Truck was 4310 lbs, what do u guys think about it?
Old Apr 30, 2016 | 02:05 AM
  #127
Jake75's Avatar
is that with you in it?
Old Apr 30, 2016 | 10:17 AM
  #128
Without me
Old Apr 30, 2016 | 06:53 PM
  #129
Forgot to mention this was with just under 1/2 tank of fuel
Old Apr 30, 2016 | 07:55 PM
  #130
GMCtrk's Avatar
that seems lighter than I would have expected. I'd be happy. If you're average weight you're looking at 4500 or so raceweight
