Vortec350ss 2005 Sierra Denali - Forged 370 and cog driven TVS2300
Old Jul 14, 2016 | 10:08 PM
  #871
Vortec350ss's Avatar
Originally Posted by Schiavonske1013
I honestly would consider taking a look at these sensors. Not sure how you would graph on a tuner, my father is a mechanic so I have access to a snap on scanner, but my old tahoe would cut out consistently at 4100 rpm. You could stay under that and it would run fine, but hit 4100 rpm and regardless of gear, speed, throttle position, it would cut the signal to the coil. Noticed the crank position sensor would stop giving a signal at 4100 rpm, changed it and never had an issue after. Odd, as this was a 99 and all it provided was a 0/5v reference if it hit a tooth on the crankshaft's target wheel, but it worked.
And you didnt get a service engine code? Sounds kind of like what I am dealing with... Maybe I'll try that.
Originally Posted by GMCtrk
Know anyone local with efi live? If you were local I'd let you use mine and put a good cos3 tune on there.
I'm not sure. No one that local anyway. At this point would EFI live be able to tune my truck since I have changed operating systems with HPT?
Originally Posted by Atomic
If you have an oscilloscope you can go old school on the sensors.
If I knew what that meant I may try it.
Old Jul 14, 2016 | 10:33 PM
  #872
1FastBrick's Avatar
Custm2500's Rude Friend
If you have a COS with HPT, EFI wont read it. You will need to go back to stock and build a new COS in EFI Live.
I know for a fact you can do the Crank relearn with EFI live on your truck.
Otherwise find someone with a snap on scanner to do it.
Old Jul 15, 2016 | 03:51 AM
  #873
03sierraslt's Avatar
Hpt should do it as I've done it many times in the past, but haven't done it with 3.0-3.2
Old Jul 15, 2016 | 11:01 AM
  #874
HPT **SHOULD** be just as capable at doing a crank relearn as well. the new version of the software is just seems half baked to me.
Old Jul 15, 2016 | 04:13 PM
  #875
1FastBrick's Avatar
No... Say it isn't so...
3.0 officially came out and lasted what, like 4 months... Now 3.2 is out...
It was in the scan tool software I believe... I haven't used it though since the new software.
I do have an old 2.23 and a 2.24 copy of the CD if you need the older software.
Old Jul 15, 2016 | 05:35 PM
  #876
Atomic's Avatar
I have a gauge for that
Cant go back to the older ones after you upgrade, it flashes the box with newer firmware.
Old Jul 16, 2016 | 09:03 PM
  #877
GM1697's Avatar
Originally Posted by atomic
cant go back to the older ones after you upgrade, it flashes the box with newer firmware.
gay
Old Jul 16, 2016 | 09:10 PM
  #878
BlackGMC's Avatar
Resident Retard
Why are you needing todo a crank relearn? Are you getting codes or change the pcm?
Old Jul 16, 2016 | 09:17 PM
  #879
You should do it after changing sensors, motor, pcm etc. He never did. Actually you should do it after changing cam but I haven't and I know many don't.
Old Jul 17, 2016 | 02:22 AM
  #880
I didn't think I needed to do a crank relearn but I need to sort out this issue. I am baffled as to what it could be. I think the crank relearn helped it but I honestly don't know.
