Vortec350ss 2005 Sierra Denali - Forged 370 and cog driven TVS2300
Old Oct 14, 2015 | 05:56 AM
  #481
KevinF56's Avatar
Nice. Hope you can get it all tuned to hit the track. Only a couple weekends left.
Old Oct 14, 2015 | 09:13 AM
  #482
Vortec350ss's Avatar
Looks like a torched another coil. On my ride home last night I got another misfire. At this point I am leaning toward a bad ground. I will be testing the wires to the coil within the next few days, and I will be double checking all the ground wires.
Does anybody have any suggestions?
Old Oct 14, 2015 | 09:38 AM
  #483
Atomic's Avatar
I have a gauge for that
On the same cylinder or side? Sure you arent getting any arcing from a burnt or cracked wire?
Old Oct 14, 2015 | 10:03 AM
  #484
silver-mod-o's Avatar
Hunt&Fisherator
Replace your plug wires and go over your grounds. Like atomic wedgie asked, same coil? Side?
  #485
I'm not sure... I havent had a chance to look. My meth indicator LED was very faintly flashing as well though which led me to think it was very likely a ground. Could this have been caused by arcing?
Thanks for the tip Richard.
Old Oct 14, 2015 | 11:12 AM
  #486
GMCtrk's Avatar
Since you just did an engine swap, I presume this to be a bad ground until proven otherwise
Old Oct 14, 2015 | 11:13 AM
  #487
03sierraslt's Avatar
I believe that is the case also, both same bank.
Old Oct 14, 2015 | 11:19 AM
  #488
BlackGMC's Avatar
Resident Retard
I believe all thise coils in that bank have a common ground. Wouldnt it be an all ir nothing thing if it was a bad ground?
I would also check the trigger wire for tgat coil.
Old Oct 14, 2015 | 11:31 AM
  #489
Two have died in the same bank, I bet it will keep eating coils unless he finds a common denominator. A bad ground can overheat the coil, it may only be a matter of time for the others. The odds of all four dying at once would be very slim. Keep in mind he has next to no miles on it between the first coil and the current so...
Old Oct 14, 2015 | 12:14 PM
  #490
D1SCSS's Avatar
All 8 of your coils share the same ground. Its called G102. It is located on the left side of the block just behind the PS pump. The bolt that secures G102 also secures the main ground coming off of your battery... I have seen these grounds break internally and look great. Just give the wire a small tug to see if the wire stretches...
