Vortec350ss 2005 Sierra Denali - Forged 370 and cog driven TVS2300
Old Nov 4, 2015 | 05:37 PM
  #581
GMCtrk's Avatar
with how much those tensioners move around I wouldn't be surprised if it or the belt hits the tube/coupler.
Old Nov 4, 2015 | 05:41 PM
  #582
03sierraslt's Avatar
Originally Posted by camarokid6771
back onto the topic of larger reliable DBW throttle bodies could a LSA or ls9 throttle body be bored to 102mm?
how much higher could you space up the blower and still clear the hood? if you had enough room it would get the intake tube above the fans
You cannot exceed the bore of the throttle blade so no. Unless you changed the blade also, and maybe the shaft.
Old Nov 4, 2015 | 06:03 PM
  #583
camarokid6771's Avatar
I know a new blade would be needed, where I was going is there enough meat on the casting to go 102 and would the TB motor be strong enough to hold the bigger blade open
Old Nov 4, 2015 | 07:12 PM
  #584
Vortec350ss's Avatar
Yea I am worried about that for sure.
Old Nov 4, 2015 | 07:26 PM
  #585
BlackGMC's Avatar
Resident Retard
Wuss....
Old Nov 4, 2015 | 07:29 PM
  #586
It's nothing a 100mm idler cant fix...
Old Nov 5, 2015 | 08:49 AM
  #587
GM1697's Avatar
how'd the test drive go
Old Nov 11, 2015 | 09:31 AM
  #588
Finally had it out for a test and the belt does not hit the intake tube as far as I can tell, so that's great.
The tube also really helped my loss of boost, but its still there to a much smaller extent. I think this is in large part due to the 90mm throttle body at this point.
Next on the project list may involve being forced to upgrade to a return style fuel system... seems with minimal pressure drop in the returneless system I run out of injector. As soon as I go WOT fuel pressure drops to about 50PSI and stays there. At 15PSI manifold pressure that means my injectors feel like they are only getting 35# of fuel pressure. At that level they can really only handle 700 HP. Obviously meth helps that equation, but I still go lean fairly early despite short shifting.
I think my best bet to maximize my 83# injectors and the single 450 I will need a base pressure of 50#, increasing to 65-67 at full boost. At 65PSI the 450 should flow 368 LPH, and at 95% IDC my injectors can flow 365LPH. Enough for nearly 850HP letting meth take me the rest of the way there... wherever 'there' is.
Old Nov 11, 2015 | 09:35 AM
  #589
GMCtrk's Avatar
I would add another pump to be on the safe side
Old Nov 11, 2015 | 01:00 PM
  #590
Run a 255 primary and 450 secondary.
