Spoolin's attempt to Spool...
Old Jan 16, 2011 | 10:39 AM
  #201
Wilde Racing's Avatar
How do I change this text
Yep they give the radiator a nice cushy place to hang out..
So the fact that the down pipe is coated silver but the rest is coated black is driving me and all the IR heat nuts.....
Old Jan 16, 2011 | 01:48 PM
  #202
stock48's Avatar
9 Second Truck Club
Originally Posted by Spoolin
I've just blown them out up to this point, but plan on using a really soft bristled pipe tube cleaner. I've already removed a couple loose rubber chunks with my finger and just shaking it so I know there's more in there. It will be clean before start up though!!
Thanks bro!!
Lol...awwwww
Yeah I have to agree!!
Thanks Jarrett, shouldn't be too much longer, I hope. Maybe end of the month or early feb should be first start up. Found out that my valve covers don't support coil brackets so I'm gonna have to do a remote mount set of brackets, either that or I use the stock covers and have no PCV system which is obviously no bueno!!
Why can't you run the valve covers that are on there? They never gave me any trouble...
Old Jan 16, 2011 | 01:54 PM
  #203
Spoolin's Avatar
GFYS and STFU
I could/can, but for the PVC system that I have set-up won't work as well with stock valve covers. The ones I have have a -8 Bung welded on them, and I have some lines that will run from the valve covers to an electric vane pump.
Old Jan 17, 2011 | 12:03 AM
  #204
Spoolin's Avatar
GFYS and STFU
FML...I hate my truck!!!
Just one of those days I guess.
Old Jan 17, 2011 | 12:26 AM
  #205
SLO TRUCK's Avatar
I feel ya on that one. Been hating mine for like 8 months. LOL HKE Should be done with the new bullet then i will like it again.
Good luck man.
Old Jan 17, 2011 | 06:13 AM
  #206
JimS's Avatar
You'll be very glad you did the undercarraige clean up thing. And I'm glad I'm subscribed!
Old Jan 17, 2011 | 04:32 PM
  #207
Spoolin's Avatar
GFYS and STFU
What wire gauge do I need for the following?
Twin Fuel pump power supply: ('m guessing 10)
Battery ground:
Regular harness stuff(sensors and such):
Old Jan 17, 2011 | 04:43 PM
  #208
Atomic's Avatar
I have a gauge for that
I would use 10 for the pumps, 18ga for the sensors, and at least 4 for the battery, but more likely 2 or 0. Welding cable works well for the big battery connections.
Old Jan 17, 2011 | 04:48 PM
  #209
Spoolin's Avatar
GFYS and STFU
Roger!! Thanks Richard, heading out now to get the stuff I need! Also do you remember what someone told you that we "should" run for inside the tank? I remember it was 10 gauge but he said it was something special no?
Old Jan 17, 2011 | 05:12 PM
  #210
Atomic's Avatar
Yea, it was Daryn in my build thread.... not PVC...ill look in a second
Originally Posted by Daryn
PTFE wire is the preferred wire but you can get away with polyethylene coated too... pvc is a big no no!
