Spoolin's attempt to Spool...
#202
9 Second Truck Club
I've just blown them out up to this point, but plan on using a really soft bristled pipe tube cleaner. I've already removed a couple loose rubber chunks with my finger and just shaking it so I know there's more in there. It will be clean before start up though!!
Thanks bro!!
Lol...awwwww
Yeah I have to agree!!
Thanks Jarrett, shouldn't be too much longer, I hope. Maybe end of the month or early feb should be first start up. Found out that my valve covers don't support coil brackets so I'm gonna have to do a remote mount set of brackets, either that or I use the stock covers and have no PCV system which is obviously no bueno!!
Thanks bro!!
Lol...awwwww
#203
GFYS and STFU
I could/can, but for the PVC system that I have set-up won't work as well with stock valve covers. The ones I have have a -8 Bung welded on them, and I have some lines that will run from the valve covers to an electric vane pump.
#205
#208
I would use 10 for the pumps, 18ga for the sensors, and at least 4 for the battery, but more likely 2 or 0. Welding cable works well for the big battery connections.
#209
GFYS and STFU
Roger!! Thanks Richard, heading out now to get the stuff I need! Also do you remember what someone told you that we "should" run for inside the tank? I remember it was 10 gauge but he said it was something special no?
#210
