Slow and getting slower
Old Sep 3, 2011 | 10:13 AM
  #281
sprayedenali's Avatar
torch + good impact gun = alot easier!
Old Sep 5, 2011 | 07:24 PM
  #282
1FastBrick's Avatar
Custm2500's Rude Friend
Old Sep 5, 2011 | 09:42 PM
  #283
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
I know Mitch knows what he's doing but:
Penetrating-Lubricating Oils
I've personally seen this stuff loosen bolts & rusted piston rings when nothing else could.
edit: their slogan is "the oil that creeps" & it's the truth!
Old Sep 5, 2011 | 09:45 PM
  #284
Atomic's Avatar
I have a gauge for that
rained all day....need to get new leaf pack bolts so it will work with the axle....bolt head diameter needs to be 1/2" or less and at least 2 3/4" long.
Old Sep 5, 2011 | 09:49 PM
  #285
i use kroil all the time at work! its great stuff!! but sometimes the red wrench is your best bet....
working on stuff from the 50s and before all the time, you figure out how to loosen stuck bolts! hahaha
Old Sep 6, 2011 | 06:22 AM
  #286
custm2500's Avatar
Ph.D. in HUBRIS
If you are talking about the "bolt" that goes through the center of the spring pack it is called a spring pin.
The spring pin will have a 1/2" round head because it is meant to locate the axle.
Old Sep 6, 2011 | 08:32 AM
  #287
Atomic's Avatar
Yep, I had to do the same thing when I originally did my 14b swap on my other truck. I just used an allen head bolt of the right length, worked fine.
Old Sep 6, 2011 | 05:10 PM
  #288
custm2500's Avatar
Ph.D. in HUBRIS
I rounded the corners of a bolt head of once and it worked fine. Never thought about the allen headed bolts.
Old Sep 9, 2011 | 12:42 AM
  #289
Atomic's Avatar
So I decided to get new pins and drill the spring perch on the axle slightly larger. I dont want to risk one of these shearing off...and by the way, these things are impossible to find so I got some tuff country ones off summit.
Also got this cool thing in the mail, I dont see why more guys dont use these for oil feeds. I plan on using it for my oil temp sensor.
And the thread pitch for our oil pans is 3/4-16
Got an MRI on my wrist today. Kinda fun watching xray while the doctor moves the needle around in my wrist to inject the dye without really feeling anything...except now its sore. Ill know in a few days if I tore anything...
Old Sep 11, 2011 | 10:15 PM
  #290
Atomic's Avatar
Glad to see everyone cares
Got a present for the truck today, no pics yet, but its awesome
